PrintShop Web Connect
The PrintShop Web Connect Input task allows the use of a PReS Workflow in order to drive PrintShop Mail Web requests. A Send to PReS printer is available to PrintShop Mail Web operators selecting Generate Output in the PrintShop Mail Web Order Manager, providing an easy way to send jobs toward the PrintShop Web Connect Input task, in order to take full advantage of PReS Workflow's built-in automation tasks.
Note: PrintShop Mail Web and PReS Workflow must be installed on the same server in order to make the PrintShop Web Connect Input task available in your PReS Workflow.
This task does not poll an input, it sits there and waits for a job file to be sent by the local PrintShop Mail Web installation.
When the job is received from PrintShop Mail Web, it is saved as a job file. No further processing is done on the file.
The task outputs the job file as is, with no evaluation or modification. The format of the job is PostScript generated by PrintShop Mail Web.
PrintShop Web Connect Preferences
A PrintShop Web Connect preferences page, accessible via the PReS Workflow Button | Preferences | PrintShop Web Connect, allows to provide operator credentials to your PReS Workflow configuration.
It is mandatory to fill both the user name and password fields (with the values of an existing user on the PrintShop Web server) in order to use the PrintShop Web Connect Input task.
Note: It is also mandatory to send your configuration to your PReS Workflow service since the PrintShop Web credentials are included in the *.cfg file (See Sending a configuration), which is updated every time the configuration is sent to the service via the Send Configuration button.
- All documents: Lists, in a hierarchical view (Company -> Publication Types -> Documents), the PrintShop Mail documents already existing on the PrintShop Web server.
- Refresh: Click to update the list of PrintShop Mail documents available on the PrintShop Web server.
"Other" Tab
- Job Information group
- Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
