Serial Input
Serial Input tasks receive files sent to a serial port on the computer running PReS Workflow. All the Serial Input tasks in a PReS Workflow configuration share the same general properties, which are configured through user options (see Serial Input plugin preferences). Only the properties set in the Other and Error tabs are specific to individual tasks.
This task does not poll an input, it sits there and waits for a job file to be sent through the Serial connection.
When the job is received through the Serial connection, it is saved as a job file. No further processing is done on the file.
The task outputs the job file as is, with no evaluation or modification.
  • Since Serial Input tasks have no specific task configurable properties, this section contains no property information.
"Other" Tab
  • Job Information group
  • Backup input files: Check this to save a copy of each data file that is captured by your input. These files are saved in the PReS Workflow Tools working folders under the "Backup" folder.
Job Information definitions
  • %1 - Source file name: Contains the name of the job file as specified by the software that sent the job.
