2011-03-29
Dismiss this until next updateThis documentation has been updated
The latest version of PrintShop Mail is currently 7.1. This documentation was updated on 2011-03-29 and covers the changes made in this version. If you are still using an older version of PrintShop Mail, you can access its documentation by using the Version: menu at the top-right corner of this screen.
If you wish to upgrade to PrintShop Mail7.1, you can do so via the Upgrade Request page. Note that in order to upgrade, you will need a valid OL Care contract as of 2010-09.
Print To Web
Print to Web allows you to print PrintShop Mail documents to PrintShop Mail Web. The output will be generated on the PrintShop Mail Web server, not on the computer where the PrintShop Mail document is created.
From the File menu, select Print to Web…
When selecting Print to Web… option, the PrintShop Mail document can be saved before it is uploaded, otherwise the original document will be sent to PrintShop Mail Web.
The following options are displayed in the Print to Web dialog:
Save Print Options: This option allows you to store specific print options with the PrintShop Mail document.
Print: When printing  the document  and its related files will be sent to PrintShop Mail Web print queue.
Directsmile note: In order to print PrintShop Mail documents using DirectSmile objects with a PrintShop Mail Web server, you must make sure that the PrintShop Mail Web server has the proper access to the DirectSmile server.
