2011-03-29
Dismiss this until next updateThis documentation has been updated
The latest version of PrintShop Mail is currently 7.1. This documentation was updated on 2011-03-29 and covers the changes made in this version. If you are still using an older version of PrintShop Mail, you can access its documentation by using the Version: menu at the top-right corner of this screen.
If you wish to upgrade to PrintShop Mail7.1, you can do so via the Upgrade Request page. Note that in order to upgrade, you will need a valid OL Care contract as of 2010-09.
Folding Lines
You can use folding lines to determine where to fold documents. Folding lines are printed on the visible part of the document (the part that will remain when the document is cut to the right size, for example they are also printed when there is no bleed margin). Unlike guide lines, folding lines are part of the print output, they are printed on either side of the document.
To add a folding line
Windows
1-Insert from the Insert menu
From the Insert menu, select Folding line
Select Horizontal or Vertical line.
Drag the mouse to the exact position where you want to place the folding line and left click on it.
2-Insert from the Ruler
Right click on the ruler. The contextual menu will show “Guide line” and “Folding line”.
Select Folding Line.
Use the horizontal ruler to add a vertical line, and the vertical ruler to add a horizontal line. Left clicking on a ruler adds either a guide line or a folding line, depending on the icon displayed in the top left corner of your work area.
Mac
From the View menu, select Layout Ruler. Select either a horizontal or vertical guide line.
View   the window
To change a folding line:
To modify a folding line position
  1. Select the Folding line.
  2. Right click on it.
  3. From the menu select "Position"
    The window will show the current coordinates of the folding line.
  4. Enter the new coordinates for the line position.
To remove a folding line
It is possible to remove a folding line by dragging it to an invalid location outside the layout. The drag cursor is updated to reflect whether releasing the mouse button will move or remove the folding line. Alternatively right click on the folding line and from the menu select " Remove" .
