2011-03-29
Dismiss this until next updateThis documentation has been updated
The latest version of PrintShop Mail is currently 7.1. This documentation was updated on 2011-03-29 and covers the changes made in this version. If you are still using an older version of PrintShop Mail, you can access its documentation by using the Version: menu at the top-right corner of this screen.
If you wish to upgrade to PrintShop Mail7.1, you can do so via the Upgrade Request page. Note that in order to upgrade, you will need a valid OL Care contract as of 2010-09.
Imposition Settings
The Imposition Settings section applies only to this document. When changing these options, they are saved with your document and may change when opening or creating a new document.
To open the Impositions preference dialog:
  1. (Windows): From the Edit menu (CTRL+K), select Preferences.
    (Mac OS): From the PrintShop Mail menu (Command,), select Preferences .
  2. In the left pane, click the Imposition Settings icon.
Available options:
