You can generate salutations with a conditional IF statement. If you have a field in your database that specifies the gender of the person, you can use it to add 'Mr.' or 'Mrs.' to the name.
First Name |
Last Name |
Gender |
John |
Abrahams |
M |
Theresa |
Johnson |
F |
William |
Fremont |
M |
This example uses the IF function in combination with the "&" operator, which allows you to combine text strings.
"Dear" & IF([Gender]="M", " Mr. ", " Mrs. ") & [First name] & " " & [Last name]
This will result in a string that always starts with Dear , continues with either Mr. or Mrs. depending on the gender, and always finish with the first name, then a space, then the last name:
First Name |
Last Name |
Gender |
Result |
John |
Abrahams |
M |
Dear Mr. John Abrahams |
Theresa |
Johnson |
F |
Dear Mrs. Theresa Johnson |
William |
Fremont |
M |
Dear Mr. William Fremont |
