This function manipulates the database output without changing the content. Its purpose is to make a conditional selection from the database.
Syntax |
IF(Logical test, Value if True, Value if False) |
Description |
Gives one of two results depending on a condition you specify. Returns <Value if True> when <Logical test> is True, and <Value if False> otherwise. |
Example |
IF([GENDER]="M", "Mr.", "Mrs.") |
In this example, the IF function checks the database field [GENDER], if it contains "M", it returns the string "Mr.". If the database field contains anything else, it returns "Mrs".
Logical test |
Logical expression that determines which of the 2 parameters values will be returned. |
Value if True |
Any expression of fieldname. Will be returned if test condition evaluates to True. |
Value if False |
Any expression of fieldname. Will be returned if test condition evaluates to False. |
You can use the IF function, for example, to create a salutation. See "Inserting a Salutation".
