7.1
2013-09-23
Barcode Functions
Barcode functions and fonts are deprecated in PrintShop Mail 7.0 for Windows. We strongly advise using the Barcode Object instead.
Available Barcode Types in PrintShop Mail:
Barcode Fonts
The table below reflects an example of which font name can be used with each barcode.
Barcode
PrintShop Mail Font Name
Example
CODABAR
PSMCbar
PSMCbarHrP24DhTt
CODE 128
PSMC128
PSMC128Bwr3P36DhTt
CODE 39
PSMC39
PSMC39HrP24DhTt
EAN 13/ EAN 8
PSMEan
PSMEanBwrP36Tt
ITF
PSMInt
PSMIntHrP72DmTt
JAN 13/JAN 8
PSMJan
PSMJanBwrP36Tt
MSI
PSMMsi
PSMMsiHr72DhTt
NW7
PSMNW7
PSMNW7HrP48DmTt
ONECODE
OneCode Barcode
PSMOneCode
POSTNET
PSMPostNet
PSMPostNetHrTt
UPCA/UPCE
PSMUpc
PSMUpcP72Tt
PrintShop Mail font name description
P = Point size. The Point size refers only to the height of the font. For example if you see C39HrP24DmTt, the P used here refers to the point size of 24.
Dh, Dm and Dl = Density (high, medium and low).The density of a barcode is the number of characters per inch (cpi) of the printed barcode. It is of great practical importance since it determines the minimum barcode length required to print the desired information. The higher the density, the shorter the barcode.
Hr= Human Readable characters. These characters are printed below the barcode.
Bwr = Bar Width Reduction. The font includes technology to reduce the width of the individual bars uniformly across the barcode without changing the center line of the barcodes.
Note: You can install the barcode fonts library from the PrintShop Mail Installers folder on the CD.
The PSMFimCodesTt font, used to generate POSTNET barcode, is a special font used by the US Post Office to separate business reply mail from other mail. The FIM font consist of four unique barcodes, each barcode represents a unique reply mail classification.
Font Information
Barcode Setup
Below are the steps for setting up a barcode. A Postnet barcode is used for this example.
  1. Click on the text tool on the Tools toolbar to draw a text box, or from the Insert menu, select Variable Text.
  2. Type a variable name, example @Barcode@.
  3. Double click on the Barcode field in the Variables panel, to open the Expression Editor.
  4. Click the radio button titled "Barcode" to display all barcode generators and select the required function from the list. A barcode function translate a numerical code to a text string, which yields the desired barcode when printed with a special barcode font. Select POSTNET by double clicking on it.
  5. As the argument to the barcode function, enter the database field that contains the code that should be translated into a barcode. Some barcode functions require another argument.
  6. Click OK.
    Note: PrintShop Mail Postnet function and font, only works with 5, 9 and 11 digit number strings. No hyphens can be in the string.
  7. Select the variable @Barcode@, and pick the barcode font, that is specified for use with the chosen barcode generator.
  8. From the Text Formatting toolbar or from the Text menu, select the desired PrintShop Mail font. Adjust the font size to show the barcode at the specified or desired size.
