Syntax |
COUNTER([Start value][,End value] [,Step size] [,Number of positions] [,Leading zeroes]) |
Description |
A counter which by default counts from the first to the last record. Arguments are optional. |
Example |
COUNTER (1,100) COUNTER (1,100, 5, 3, True) COUNTER (1, 100, 0.5, 3, False) |
Start value |
The start value of the counter. Default 1 . |
End value |
The end value of the counter. If no value is specified, the counter is never reset and will go until the end |
Step size |
The step size to the next number. Default 1. |
Number of positions |
The number of characters the counter will create. By default no extra characters will be added. Default 0. |
Leading zeroes |
True for leading zeroes, False for no leading zeroes (default). |
You can use a counter when printing tickets or numbering your mailing. You do not need to open a database within PrintShop Mail when using a COUNTER, if this is the only variable.
Example 1
The first example creates numbers, starting with 1 and ending with 100.
Code:
COUNTER (1,100)
Result:
1, 2, 3, 4, [...] , 99, 100, 1, 2, 3, [...]
The counter restarts once it has reached the end, in this case 100.
Example 2
The Second example has a step of 5, meaning it will only display every 5th number. The parameters step size, number of positions and leading zeroes have been added.
Code:
COUNTER (5,100, 5, 3, True)
Result:
005, 010, 015, [...] , 090, 100, 005, 010, [...]
Example 3
The third example has a fraction for the step size. This means that the counter increases by 0.5.
Code:
Result:
1, 1.5, 2, 2.5, 3, [...] , 99.5, 100, 100.5, [...]
Example 4
The last example, COUNTER() starts with 1 and ends at whatever number is set in Items without database (Program settings in the Preferences).
