Filter Resource Review Availability
The Resource Review page provides a centralized view of Resource allocation (effort) and availability across work items, as well as any unstaffed demand that currently exists.
Both the Allocation (top) section and Demand (bottom) section display "Availability" columns that display the amount of available working time for Resources and Roles. In the Allocation section, the "Availability" columns display values for each listed Resource.
Janice has 20 hours of availability remaining for the week of September 21st.
In the Demand section, the "Availability" columns display values for each listed Role.
There are 20 Receptionist hours that are available to assign for the week of September 21st.
The "Availability" tab on the "Filter Settings" window determines how these availability values are calculated on both sections (Allocation and Demand).
Note: This feature is only available on the new Resource Review interface.
Specifically, the tab contains two settings: "Calculate Availability on" and "Exclude Status".
Calculate availability on
The "Calculate Availability on" drop-down menu determines whether availability calculations take into account all work items and assignments in PowerSteering or only those that are displayed in the Allocation section as a result of the Allocation filters.
Note: These calculations will be applied to "Availability" columns within the Demand section as well as the Allocation section.
Selecting "Current Allocation Filter" will calculate availability for each Resource and Role using only work items and Resources that satisfy the filters under the "Allocation" tab and are displayed in the Allocation section. This option is especially helpful when users prefer to view availability through a specific scope of responsibility or testing scenario. While viewing Roles in the Demand section, it sometimes makes sense to only display the availability of Resources that belong to a particular group; availability that includes all Resources might cause managers to assume there is enough capacity and ignore the gaps in their own team. For example, if a manager must fill a Role's unstaffed demand using only Resources from a single Resource Pool, the Role availability values may be misleading if they are calculated using every Resource in PowerSteering. Restricting the results to this Resource Pool and selecting "Current Allocation Filter" prevents the "Availability" columns in the Demand section from including hours that might not actually be available.
Additionally, Resource managers may wish to use the Resource Review page to create and test certain scenarios. For example, if a large group of Projects is expected to be canceled, Resource managers can use the "Allocation" tab to filter them out and then select "Current Allocation Filter" to see how much Resource effort will become available if this scenario comes to fruition. This allows Resource managers to answer any "what-ifs" and take advantage of upcoming opportunities.
Selecting "Overall Allocation" will calculate availability using all Resources and work items in PowerSteering. This is useful for viewing a Resource or Role's "true availability", taking into account work items and assignments that are not displayed in the Allocation section. For example, a Resource with 20 displayed hours of availability for the week might be allocated to other work items that do not meet the Allocation filter criteria. Selecting "Overall Allocation" and calculating availability without Allocation filter restrictions ensures that all work items are accounted for, preventing misleading and inaccurate availability figures.
Exclude Status
The "Exclude Status" checkboxes allow users to limit availability calculations to work items of a certain status. In other words, availability calculations will ignore Resource assignments toward any work items that currently have one of the selected statuses.
Excluding work items from availability calculations based on their statuses helps keep Resource Review data accurate and strategically aligned. Resource managers may decide that inactive work items (with statuses such as "Proposed" or "Deferred") should not be included in availability calculations because they do not actually consume Resource time. On the other hand, managers might decide to include these work items because they can become active at any moment and prevent Resources from being assigned to coinciding work. This gives managers the ability to test scenarios and prevent irrelevant work from distorting Resource availability.
To determine how the "Availability" fields are calculated:
  1. Select Review → Resource Review (New) from the Navigation Menu.
  2. Select a Resource Review Layout using the "Layout" drop-down menu.
    Note: The layouts above the gray line are layouts that have been shared with you. The layouts below the line are your own private layouts.
    Note: Speak to a PowerSteering administrator if you are unsure about which layout to use.
  3. Select the Filter icon from the top of the page.
  4. Select the "Availability" tab from the top of the "Filter Settings" window.
  5. Configure the availability filters.
    • Calculate Availability on: Determine which data is used to calculate availability for the Allocation and Demand sections.
      • Current Allocation Filter: Availability for Resources and Roles is calculated using only Resources and assignments that are currently shown in the Allocation section.
        Note: See Filter the Allocation Section for more information on these filters.
        Note: When this is selected, each Role's availability is calculated using only the Resources and work items that are currently displayed in the Allocation (top) section. An exception occurs if there are no Resources with the Role on their profile displayed in the Allocation section. In this case, the Role's availability will be calculated using all PowerSteering Resources with the Role on their profile. See the example below for more information.
      • Overall Allocation: All Resources and Resource assignments in PowerSteering are used to calculate availability, not just those that satisfy the filters under the “Allocation” tab.
        Tip: This selection ensures that a Resource's "true availability" is displayed. In other words, it displays a Resource's availability after taking all work items and assignments into consideration, not just those that satisfy the "Allocation" tab filters.
    • Exclude Status: Works items with any of the selected work statuses will not count toward availability calculations in the Allocation and Demand sections.
      Note: The “Canceled” and “Archived” checkboxes are selected by default. Unselecting them could increase loading times.
      Example: Cristina has been assigned to two separate Projects during the week of September 21st: "City Park Refurbishment" and "City Bridge Reframing". She is 50% allocated to both, which means she will work 20 hours on each one (40 hours total for the week).
      In the Allocation (top) section of the Resource Review page, both of these work items are listed. Her work week consists of 40 hours, so she does not have any availability left.
      However, the "City Park Refurbishment" Project currently has a "Proposed" work status.
      The Resource Manager decides that allocations toward "Proposed" Projects should not count toward availability calculations because they are not confirmed, so he selects "Proposed" from the "Exclude Status" list.
      This means that any Resource assignments toward work items with a "Proposed" status will not be included in availability calculations, including the "City Park Refurbishment" Project. The 20 hours of Cristina's time that are allocated to this Project for the week will not be reduced from her weekly availability of 40 hours, so her availability is now displayed as 20 hours.
      Notice that the "Effort" values stay the same; only "Availability" values will be affected.
  6. Use the options at the bottom of the "Filter Settings" window to determine how you would like to apply your changes to the current Resource Review Layout.
After selecting one of the options at the bottom of the "Filter Settings" window, your Availability filters will be reflected on the Resource Review page.
