PSA 2021 R1.1 - Resolved Issues
Below is a summary of the main issues addressed by this release.
- Expense
- Financial
- Financial Planner
- Integration
- Mobile
- Reporting
- Resource Management
- REST API/SDK
- Timesheet
- Work Breakdown Structure (WBS)
- Workflows
2021.05.17.2021R1.V2.EB
Note: This page could be updated as new information becomes available.
Expense
| 701739 | TE-77861 | Fixed an issue with the Expense Manager, wherein the User ID column was missing from the exported Excel file. |
Financial
| 678347 | TE-76900 | Fixed an issue with Detailed Invoice by Project / Task with Notes report wherein the list of Projects were being sorted according to their unique ids instead of by Project Name. |
Financial Planner
| 685001 | TE-77116 | Fixed an issue with Financial Planner, wherein changes made to the Financial Planner Template were not being reflected in the Financial Planner. |
| 686403, 688155 |
TE-77129 | Fixed an issue with Financial Planner, whereupon modifying the period always switched to the Combined View. |
| 684996 | TE-77166 | Fixed an issue with Financial Planner where a Project’s Template was not being updated according to the inheritance model when changes were made within it. |
| 686774 | TE-7716 | Fixed an issue with the Financial Planner wherein the Cost and Revenue amounts within the Budget Summary were not displayed according to the selected Currency. |
| 695159 | TE-77560 | The Margin % by Revenue in the Financial Planner Summary section now reflects the same value of the Grand Total. |
Integration
| 686660 | TE-77162 | Fixed an issue with the AMEX Integration, wherein the Amex Credit Card Automation Service was failing. |
| 686912 | TE-77232 | Fixed an issue with QuickBooks Integration wherein some special and XML escape characters contained in Client Names were causing an error upon importing. |
Mobile
| 655259 | TE-76648 | Fixed an issue with Mobile Timesheet, wherein users were able to modify approved Leave Time Entries for a Timesheet Template having the “Prevent Users from modifying Holiday entries created automatically” and the “Prevent Users from modifying or deleting entries created from a Leave Request” settings. |
| 680312 | TE-76951 | Fixed an issue with Mobile Timesheet, wherein Project Managers without the permission to My Timesheet were unable to approve Timesheets. |
Reporting
| 666229 | TE-76694 | Fixed an issue with the Upland Analytics Project Entry Billed Amount Field within the Project Entry Details Data Source to exclude non-Billable Entries in the calculations. |
| 672850 | TE-76646 | Fixed an issue with Upland Analytics, whereupon returning to the main Report, the Drill-Down reports lost their applied filter(s). The issue has been fixed by introducing a new option to Save filters as Default. |
| 660611 | TE-75980 | Fixed an issue with Upland Analytics Pivot Reports wherein the order of the Pivot columns was not retained and the Subtotal was incorrect when the report was sent via Subscriptions. |
| 658979, 683411, 686769 |
TE-75965 | Fixed an issue with Upland Analytics wherein a failed Subscription Notification was being sent for a Report that was running successfully. |
| 659447, 664530 |
TE-75939 | Fixed an issue with Upland Analytics Pivot Reports wherein the second and third pivoted columns were missing their Total Sum. |
| 654251 | TE-75763 | Fixed an issue with Upland Analytics Reports wherein a Filtered Custom Field column was missing when previewing the Report. |
| 643494 | TE-75063 | Fixed an issue with an Upland Analytics Report containing UA Custom Fields that was failing. |
| 628335 | TE-74321 | Fixed an issue with Upland Analytics wherein an attachment would be missing from a Subscription Email sent to a User if the User had spaces at the end of their UserName. |
| 626723 | TE-74295 | Fixed an issue with the sorting order when a Subtotal calculation was applied to the first column within an Upland Analytics Report. |
| 626571 | TE-74210 | Fixed an issue with Upland Analytics Subscriptions wherein some Users were missing from the User Recipients list. |
| 613674 | TE-73576 | Fixed an issue with Upland Analytics wherein a certain folder and containing reports were visible to Users that were not part of the folder sharing. |
| 581570, 616502, 660611 |
TE-71442 | Fixed an issue with the applied sorting order of certain Upland Analytics reports that were either exported or sent via email subscriptions. |
| 578071 | TE-70754 | Fixed an issue wherein a User with a deleted Home Page report was unable to access Upland Analytics. |
| 410306, 547057, 598776 |
TE-69062 | Folders in Upland Analytics can now be shared with PSA Groups and Security Profiles. |
| 395944 | TE-67841 | The option of editing the On Page Filters from the Settings popup has been removed. |
| 467266, 643018 | TE-64159 | Permissions applied at the Folder level now also apply to Reports and Dashboards that are contained within. |
| 451134, 456517, 575924, 599475, 665973 |
TE-63526 | Fixed an issue where the OnPage filters values were lost once the report was loaded. A new option has been introduced on Filters to "Save filters as default". |
Resource Management
| 687422 | TE-77210 | Fixed an issue with the Work Plans wherein a server error was being triggered upon accessing a Work Plan if the View’s Timeline start was set to Next Quarter. |
REST API/SDK
| 685469 | TE-77241 | Fixed an issue with REST API/SDK wherein the PUT "BillingContactId" request to the api/v2/Clients/{id}/InvoiceOptions was failing. |
| 676593 | TE-76776 | Fixed an issue with REST API/SDK wherein the sorting filter for the GET “TimeEntries” was not ordering the data as expected. |
| 650979 | TE-75672 | Fixed an issue with REST API/SDK wherein the GET call for the ClientPOs was resulting in an error message. |
Timesheet
| 690676, 693561, 694610, 694790 | TE-76864, TE-77744, TE-78039 |
Upon accessing the Timesheet Administrator View, you must now first perform a search to display the required data. Note that the search may take several minutes depending on the selected date range and the number of Users. |
| 681617 | TE-76982 | Fixed an issue with the Timesheet Manager where not all Work Types were listed in the Task Work Type on-page Filter. |
| 682602, 682821, 683078, 685689, 686499, 691793, 692444, 692930, 693085, 694603 | TE-76990 | Fixed an issue with Timesheet approval/rejection wherein it was not possible to transition a Timesheet in an Open state which was flagged as Approval. For complete details refer to Timesheet Manager Mass Action functionality (TE-69174, TE-76518). |
| 682877, 690754, 692877, 695620 | TE-77019 | Fixed an issue with the Timesheet Manager sorting capability wherein the applied sorting order was lost upon taking an action on a Timesheet. |
| 683799 | TE-77070 | Fixed the French message to now read “Aucune transition disponible” when No available Transitions exist. |
| 687621 | TE-77212 | Fixed an issue with the Assigned Timesheet by Projects View wherein the drawer’s active viewing area did not allow vertical scrolling, limiting one from viewing the complete list. |
| 686691 | TE-77218 | Fixed an issue with Timesheet Manager wherein managers attempting to transition subordinate Timesheets that were not directly assigned to them would fail. |
| 687530, 695159 | TE-77325 | Fixed an issue with Timesheet Manager wherein the View’s Description tooltip remained visible on the page blocking the Calendar and Rejection buttons. |
| 690159 | TE-77298 | Fixed an issue with Timesheet Manager wherein the Timesheet Approval Status tooltip remained visible on the page. |
| 695483 | TE-77531 | Fixed an issue with the Timesheet Administrator View wherein searching by “Lastname, Firstname” or by Workflow was not returning any results as expected. |
| 682890 | TE-77565 | The Administrator Transitions are now available from the Timesheet Manager Assigned Timesheets View for users assigned the Timesheet Administrator Workflow Role. |
| 685226, 684996 | TE-77143, TE-77159 | Fixed multiple issues with the way various User Defined Fields were being saved in Project Edit. |
| 686484 | TE-77137 | Fixed an issue with Group Approvers page wherein the Selected Users list was pushed outside of the viewing area. |
| 681027 | TE-77014 | Fixed an issue where Rate Rule associations could be created past the user Termination date. |
| 684981 | TE-77092 | Fixed an issue with Project Edit whereupon saving a Project Status Report having User Defined Fields inheriting from the Project and clicking any Project tab resulted in an error message. |
Workflows
| 684289, 688526, 692848 | TE-77101 | Fixed an issue whereupon attempting to reassign an Invoice or Work Process State failed. |
