Qvidian for Web
Qvidian for Web is easy to use, offering a similar experience to functionality already available in Qvidian for Office, such as searching for and consuming content. Qvidian for Weballows you to:
- Find and consume your content quickly and easily on various RFP portals, websites, and web-based tools, such as Google Docs, Sheets, and Slides.
- Quickly access and download content stored in Qvidian.
- Quickly copy answers and paste as needed.
- Focus your search using Folders and Filters.
- Find the right content with Suggested Filters.
- Easily see content preview or details.
- Read and leave feedback on content.
Once loaded, Qvidian for Web, which operates in a separate window, interacts with web pages to add a context menu option, allowing you to search Qvidian with your selected text.
Installing Qvidian for Web
Qvidian for Web is available from the following stores:
In each case, there is a version for EU hosting and a version for US hosting.
Accessing Qvidian for Web
Note: The following application permissions must be enabled to access Qvidian for Web: "Allow user to log into Qvidian for Web".
- After installation, click the Extensions icon and select the Qvidian for Web.
- The "Upland Qvidian Welcome" sidebar will appear.
- Click Log in on the "Upland Qvidian Welcome" sidebar. The "Upland Qvidian Log In" dialog appears.
- Enter your Upland Qvidian User Name and Password and click Log In.
Tip: You may want to move the sidebar to another screen or re-size the browser window so you can see both items on the same screen.
Updating the Qvidian for Web Settings
- Click the Menu
icon. - Select Settings from the dropdown menu.
- Specify your Subscriber GUID if you are using SSO. Your Subscriber ID, which is entered into your Subscriber GUID field, can be found in the "About" area within the header of the Qvidian interface.
- Select the Disable SSO authentication checkbox to turn off SSO and use an explicit login.
- Select the Turn on debugging mode checkbox to enable the debugging window. This setting is only used when you need to provide customer support with more information regarding an issue that you are experiencing.
- Click Save.
Accessing Upland Assist
- Click the Menu
icon. - Select Help from the dropdown menu.
- To open the Help Center or Community in a new browser tab, elect the Help Center or Community links within the Resources section.
- To search directly in the Upland Assist dialog, enter your question or desired topic directly into the Find your answer search bar and click the Search
icon. Search results will populate directly below in the Find your answer section. - Click the desired answer to learn more. Help Center topics will be identified with a Help Center topic
icon. Community topics will be identified with a Community topic
icon. - Click View More Results to see more answers.
- Click the Contact Support link if you need more help.
- Click X to close the Upland Assist dialog. Click the minimize icon to hide Upland Assist.
Logging out of Qvidian for Web
- Click the Menu
icon. - Select Logout from the dropdown menu.
