Create a Report
Note: Data sources in this step are provided for example only. Your data sources will depend on the modules licensed and the permissions granted. For more information, see Data Sources/Views.
- Click the Add report name box and type the name for your report.
Type values in this box to filter and find the folder where your report or graph/chart will be saved.
- Do the following to work with the fields in list:
- All Fields
- Dimensions
- Measures
- Date
- Start typing in the Searchitem box to begin searching for available fields.
- Click Fields and Custom Fields to alternate between the tabs.
- Drag and drop the fields to add to the report from the Fields list to the Layout section.
- Click
to add a pivot. For more information, see Add a Pivot. - Optional: Click
to view the available Report Settings options: - Show Subtotal: By default, None is selected which means the report will not display a subtotal:
- First: A subtotal will display in the first column of your report.
- All: A subtotal will display for every numerical column of your report.
- Show Total: By default, Yes is selected. If you select No, a total will not be displayed in your report.
- Optional: Click Preview to preview your report. Your report displays in View Mode.
To send the report or graph/chart offline in an email.
To stop loading and abort the report or graph/chart.
To continue waiting and view the report or graph/chart.- Click Save to open the Save context menu
- Save: Selecting this option will save the report without exiting the report edit page.
- Save as copy: Selecting this option will save a copy of the report. You will need to rename the report in the Navigation Menu.
- Save & Close: Selecting this option will save the report and close the report edit page. The report will then run.
- Save & send by email: Selecting this option will save the report and close the report edit page. A modal window will then give you the options to send the report. For more information, see Email a Report.
- Save & Create new: Selecting this option will save the report and close the report edit page giving you the option to create a new report.
Note: You must add at least one filter.
Click Save to save your changes or Cancel to return to your Report Layout page.
You can preview your report at any time by clicking on the Preview button.
No Data Available displays when there is no data retrieved/found.
The following message displays when a report or graph/chart takes too long to render:
Click one of the following:
