Setting Message Options
You can set the following Options from a message or distribution screen.
To configure message Options:
In Create Distribution, click the Options button.
On the Distribution tab, enter the following information, as applicable:
Routing Sheet – Select either a Simple or Standard style. For example, a standard style may include company information and/or a disclaimer.
Expiration – Identify whether or not the distribution expires, and if so, when:
Never – The Distribution has no expiration date.
On Specific Date – Enter the specific date at which it expires. (Click the text field and select a date from the pop-up calendar.)
Expires – Enter the amount of Days/Weeks/Months/Years after the Date Created/Date Modified/Date Last Used at which the Distribution expires.
Publish as public – Publish the distribution as available to users who subscribe to a user’s public distributions.
Retain Routing Sheet in delivered document – Deliver the Routing Sheet with the document. Normally, the Routing Sheet is not delivered.
Single use – Indicate that the message or distribution is only intended for one-time use.
Sort at top of devicelisting – Places the distribution within a listing.
On the Prompts tab, you can indicate that when you perform a task, the system will request that you enter custom Prompts, such as a client number or for example, in certain legal departments or law firms, a matter number.
On the Custom Options tab, you can select from Custom Options that your Administrator may have created and configured for your organization's use.
On the Scan Settings tab, you can select any scan settings you want applied to the message or distribution.
