Setting Recipient Properties
You can set Recipient Properties while adding a Destination to a message.
To configure Recipient Properties:
In the Destination tab, enter the following information, as applicable:
Email – Enter a Name, Company, Business phone, and destination Email address.
Address Type – Select from the address types To, Cc, or Bcc.
Filename – Enter the name of a specific file to attach to your transmission.
Deliver as – Select the final format type.
Fax – Enter a Name, Company, Business phone, and destination fax number.
Cover Sheet – Choose whether to send or not send a cover page and select from a stored list of styles.
Access Code – Enter an access code (such as “9” to reach an outside line for faxing), request a preview of your transmission before sending, specify that a fax is sent only to a secure fax destination, or hold for Preview before sending.
Printer – Enter the IP address of a printer destination.
Copies – Enter the number of copies to print.
Folders – Select a local or cloud-based Folder location (set up by the system administrator).
In the Advanced tab, enter the following optional information:
Stamp – Apply a document stamp to each page of the delivered file. This only applies to .PDF output files.
Priority – Select Normal, Low, or High to determine the priority of the sent message.
Do not deliver before – Enter a date for message delivery.
Encrypt – Set a password to be applied to the final delivered document. This only applies to .PDF output files.
Bookmark individual documents using – Enter an electronic bookmark.
Confirmations – Select either Fails or Fails or Succeeds.
Click OK when finished.
