Compose Bypass
The Compose Bypass can be used for any file that normally would fail. This composer allows specific rules to be created so that files of that type are submitted to the server along with other attachments that are passed through. For example, a user could send a PDF file and a ZIP file to the server so that the PDF and ZIP files are included in the delivered message.
Note: In order for files to be passed through the server, they must match a rule that has the Document Delivery Format set to Deliver Original Format.
To enable the Compose Bypass for a composer type
  2. On the console, expand the Server Administrator tree and navigate to Components.
  3. Double-click on Compose.
  4. Click the Conversions tab.
  5. Click the New button. The New Conversion Rule dialog box appears.
  6. Type a name for the file type that will use the MFP conversion engine.
  7. In the Copy conversion rule from box, click the arrow and select mrp via Compose Bypass (Compose Bypass) as the conversion engine for this type of MRP files.
Note: MEDITECH MRP files use the Compose Bypass option by default.
  1. Click Next and then Finish.
  2. Click OK.
About Compose Component
File Conversions, Composers, and Properties
Working with Composers
GhostScript Parameters
