Modifying Registered User General Properties
You can modify General properties for the registered user by using the Server Administrator > Registered Users node.
To modify the General properties for the registered user
  2. In the console tree, expand the server.
  3. Click Registered Users. The users are listed in the details pane.
  4. Double-click the user name whose properties you want to  modify. The Properties page opens.
  5. In the Name text box, enter the user name.
Tip: Optionally, you can click Browse to browse your company's address book and select a user. The Global Address List dialog box will be populated if the connector for your company's mail server (Exchange/Notes) is configured correctly.
  1. In the E-mail text box, enter the email for the user.
  2. In the RuleSet text box, enter a Ruleset.
Note: A ruleset is a tag that you can assign to a registered user. The ruleset will have a corresponding routing rule. This feature allows you to apply custom routing rules to individual users, such as printing inbound faxes to the user's printer or sending the fax via e-mail to the user's assistant. You can assign the same ruleset to multiple users, but each registered user can have only one ruleset associated with the registered user properties.
  1. In the Printer text box, enter the path to the user's printer.
  2. Click Add beside the Assistants text box.
  3. In the E-mail text box enter or browse the email address of the Assistant.
  4. Click OK to go back to the Properties page.
  5. Click OK to save your changes.
Registering a New User
Modifying Registered User Properties
Modifying Registered User Approval Properties
Modifying Registered User FaxCenter Properties
