About Components
                                            A component is a part of the
All components are managed by a Windows service called the Component Manager that manages the flow of messages through the components and processing steps of a message. Except for the Compose component, you do not need a special license to run these components. Also, you cannot delete components from the server.
Note: The server may use all or only some components based on your configuration.
The following table describes each component installed with the server.
                                                             Component  |
                                                             Description  |
                                                         Determines whether a message needs to be approved before the server can continue processing it for delivery.  |
| Holds a message that is waiting to be approved. | |
                                                         The Barcode extractor allows the server to read and process barcoded cover sheets (or separator pages) generated by the CA Records Manager web client.  |
                                                         Extracts billing data for CostRecovery.  |
                                                         The Document Collection Key property acts as a locator key to help the Data Extractor component identify and route documents to the correct Document Collection.  |
                                                         Converts messages and documents into the appropriate format for delivery.  |
                                                         Allows the server to read and process barcodes and identify values in scanned document pages.  |
                                                         Holds outbound messages in the sending queue until they can be delivered by the appropriate connector or delivery mechanism.  |
                                                         Determines the appropriate delivery method for all messages—inbound and outbound.  |
                                                         Detects, decodes, and applies Embedded Directives.  |
                                                         Holds inbound faxes that reside in FaxCenter until a FaxCenter user routes them to the appropriate recipients.  |
                                                         Looks up a DID or DTMF number and finds the appropriate recipient for an inbound fax.  |
                                                         Performs archiving and cleanup functions on the server.  |
| Generates and sends notification messages from the server to the email accounts of message senders and recipients when important events occur during the processing of a message. | |
                                                         Determines whether a message needs to be previewed before the server continues processing it for delivery.  |
| Holds a message that is waiting to be previewed. | |
| Determines whether the recipient of a secure fax has registered with the server. | |
| Holds a fax until the recipient registers with the server as a secure fax destination. | |
| Determines whether a message needs to be reviewed. | |
| Holds a message that is waiting to be reviewed. | |
| Ensures that messages are delivered to their final destination in the same order in which they were submitted to the server. |
