About User RuleSets
With User RuleSets, you can create custom rules for the Upland AccuRoute server to use for processing messages. For each rule, you can select a destination, identify criteria, and specify actions to be performed. Administrators have a variety of templates for document routing with multiple destinations available. Creating User RuleSets is optional. There are Received Faxes and Default RuleSets created for you during the server installation.
Note: You can have up to five criteria in a rule. If you want to set more than five criteria in a rule, create the rule with the first five criteria, make a copy of the rule, add the next five criteria and continue until you are done.
Use the general instructions below to create your User RuleSets.
You can create User RuleSets to the following destinations.
About RuleSets
About Received Faxes and Default RuleSets
