Adding Route to Destination Column
Administrators that use DTT (Destination Translations Table) can add a Route To Destination column and view the information displayed in the
Before you begin
Add the Route To Destination Column.
Adding the Route to Destination column
You can add a Route to Destination column by using the Server Administrator > Routing > Routing Application Properties dialog box. Although the following instructions are specific to a Route to Destination column, they can also be used to add other columns you want to see in the routing table.
Note:
To add the Route to Destination column
In the Server Administrator, expand Configuration and select WebApps . The profiles appear in the Details pane.
Select a profile associated with your DTT. The Profile Properties dialog box appears.
Select the Applications tab.
Select Routing. The Routing Application Properties dialog box appears.
Select the Columns tab.
Select Add. The Column Properties dialog box appears.
See the Column Properties dialog box example below.
In the Header area, select a Header type from the Type drop-down list, for example, Text.
Type a column header, for example, Route to Destination in the Text box.
Note: You can select a pre-defined property from the Text drop-down list to use as a column header. In this scenario, you must specify a Column header name, for example, Route To Destination.
Type a description in the Description box. (optional) The description is displayed as Alt Text when users move the mouse over the column header.
Select an image type from the Image drop-down list. (optional)
In the Content area, select a cell format from the Type drop-down list, for example, Text.
Type the following property value in the Text box.
%\\prDestinationData\prDestinationLocalized%
Select OK on the Column Properties dialog box.
Select OK on the Routing Application Properties dialog box.
Select OK on the Profile Properties dialog box.
Note: In the Options area, you can specify how you want to sort the items in a column by selecting a property value and change the default column width.
