AccuRoute Desktop Client WorkSiteRESTV2 Connector
This connector is used for the AccuRoute Desktop Client and iManage Cloud and On-Prem integration. You can set up the WorkSiteRESTV2 connector for an iManage Cloud server by using Connectors in the Server Administrator.
For On-Prem server configuration only
Complete the iManage Control Center and Server Administrator steps found in For iManage On-Prem Server Configuration Only (Version 10.3.1 or higher) with the WorkWeb component 10.2.6.61 or higher.
You must also provide client access to the WorkSiteRESTV2 connector for your iManage users in the Server Administrator. In addition, client users must configure the connector in the AccuRoute Desktop Client.
To provide client access
  1. Select Configuration > Groups in the Server Administrator. The Group details pane appears.
  2. Select the appropriate group for iManage Cloud use. The Group dialog box appears.
  3. Expand Clients in the left pane, if necessary and select Access.
  4. Select the Enable members of this group as users check box in the right pane.
  5. Select the WorkSiteRESTV2 connector in the Allow group to route to box.
  6. Select OK.
For Cloud server configuration only
Complete the iManage Control Center and Server Administrator steps found in For iManage Cloud Server Configuration Only.
  6. Select OK.
See About Groups for more information.
About iManage Cloud and On-Prem Integration
Setting up WorkSiteRESTV2 Connector
AccuRoute Desktop Client WorkSiteRESTV2 Connector for Client Users
