Setting up OneDrive Folders
There are several settings available to Administrators when creating OneDrive folders in the Server Administrator. Each setting executes authorization and authentication differently at the server, client application, folder or device level.
The following settings can be used to set up OneDrive folders.
Note: You will also need to enable members of your user groups access to the OneDrive folders.
Configuring Group Permissions
