About Routing Sheets
A Routing Sheet is a page with a barcode containing the distribution instructions for a document. The barcode identifies the documents during scanning like a traditional fax cover page. You can reuse routing sheets for standard, repeated tasks.
Routing sheets specify the following information.
Who receives your document
Which communications channel is used (fax, email, folder, or printer)
Optional format conversions required for each recipient
Use a routing sheet to perform the following tasks.
Scan and route multiple documents at the same time. Routing sheets can separate documents that are placed in a feeder as a batch and each unique document set can have distinct routing rules.
Send scanned hard copy documents and electronic documents in multiple formats simultaneously through one transmission.
If you want to email a hard copy document to one recipient and fax it to another, a single routing sheet with instructions for both destinations can do so.
See a routing sheet example below.
Generating a Distributions Routing Sheet
Creating a My Files Routing Sheet
