Setting Recipient Properties
Recipient Properties are specified when creating personal distributions. You can set recipient properties when adding a destination to a message.
Choose any of the following recipient properties.
Destination
Confirmation
Advanced
Destination properties
To set Destination properties
Go to Create Distribution and select the Plus icon (+) on the Destination box.
Select a Destination type; for example, Email. The Recipient Properties dialog box appears.
Use the Destination tab to specify the following properties as needed.
Address Type – Select To, CC, or BCC.
Email – Type the recipient's email address.
Name - Type the recipient's name.
Company - Type the recipient's company name.
Business Phone - Type the recipient's business phone number.
Options - Specify the filename and delivery format.
Filename – Type the name of a specific file to attach to your transmission.
Deliver as – Select the final delivery format type; for example, PDF.
Fax - Type a name, company, business phone, and destination fax number.
Cover Sheet – Choose whether to send a cover sheet and select from a list of styles.
Access Code – Type an access code (such as “9” to reach an outside line for faxing), request a preview of your transmission before sending, specify that a fax is sent only to a secure fax destination, or hold for Preview before sending.
Printer – Type the IP address of a printer destination.
Copies – Type the number of copies to print.
Folders – Select a local or cloud-based folder set up by an Administrator.
Click OK.
See the Recipient Properties > Destination dialog box example below.
Confirmation properties
To set Confirmation properties
Use the Confirmation tab to specify the following properties as needed.
When the job fails only
When the job fails or succeeds
Notify me only and/or specify additional email addresses
Include a copy of the sent document
Save as default confirmation
See the Recipient Properties > Confirmation dialog box example below.
Advanced properties
To set Advanced properties
Use the Advanced tab to specify the following properties as needed.
Stamp – Apply a document stamp to each page of the delivered file. This only applies to PDF output files.
Priority – Select Normal, Low, or High to determine the priority of the sent message.
Do not deliver before – Enter a date for message delivery.
Encrypt – Set a password to be applied to the final delivered document. This only applies to PDF output files.
Bookmark individual documents using – Enter an electronic bookmark.
Confirmations – Select either Fails or Fails or Succeeds.
Click OK.
See the Recipient Properties > Advanced dialog box example below.
