About Include Metadata
Administrators can implement the IncludeMetaData job property to show additional columns of data when messages are delivered to the My Files folder and group folders WebApps users have access to. Additional job properties selected are used as metadata and become part of the message. Both the Filescan and My Files connectors can be used with the IncludeMetaData job property to include data required by your company's workflows.
Before you begin
  • Determine which connector is being used for My Files message delivery.
  • Determine which metadata is required for My Files message delivery.
Note: Identify which system or user-defined job properties you want to use as metadata.
  • Set up the Filescan connector if it is being used for My Files message delivery.
  • Set up the My Files connector if it is being used for My Files message delivery.
  • Set up the columns to show the metadata.
Note: The setup is different between the connectors. It is important to know which connector is being used before you continue.
About My Files Document and Folder Control
Using My Files Document and Folder Control Options
