Prerequisites: SmartHub with Amazon Kendra
Be sure to install all of the prerequisites listed for your SmartHub and backend instance.
Any issues experienced by BA Insight clients during installation are typically traced to a failure to meet the required prerequisites.
Installation Prerequisite Checklist
Requirement
Description
Completed
SmartHub Server
Operating System
Microsoft Windows Server
  • 2012 and 2012 R2: 64-bit
  • 2016
  • 2019
  • 2022
  • (Complete)
Windows Roles and Features Must have Web Server(IIS) role enabled with the followingRolesandFeaturesselected:
  • Common HTTP Features
  • Health and Diagnostics
  • Performance
  • Security
  • Application Development
    • .NET 3.5
    • .NET 4.6
      • ISAPI Extensions
      • ISAPI Filters
      • WCF Services
        • HTTP Activation
  • .NET Framework 4.6 Features
    • WCF Services
      • HTTP Activation
  • (Complete)
.NET Framework
  • .NET Framework v4.7.2 required for Windows Server versions: 2012, 2016, 2019
  • .NET Framework v4.8 required for Windows Server 2022 (included with Windows. Used automatically, by default)
  • (Complete)
Service Account (domain\user)
Local or network service account used to run the SmartHub Application pool in IIS
  • Must be in the format domain\user
  • Requires read/write access to the directory SmartHub is installed in.
Account credentials: (domain\user)
Installation Account (domain\user)
Account used to install SmartHub
  • Must be local admin on machine
Supported Web Browsers
  • Google Chrome
  • Microsoft Internet Explorer v11
  • Chromium-powered Edge
  • Other browsers unsupported*
*Unsupported Web Browsers
Other web browsers may work with SmartHub, such as:
  • Microsoft Edge (legacy)
    • To check your version of Edge, go here.
  • Firefox
  • Safari
These browsers are not officially supported by BA Insight.
Analytics Index
Elasticsearch v7.10
Secured or non-secured Elastic configurations supported.
Note: The Elasticsearch index used for the SmartHub data does not have to be the same instance use for the search index (backend).
For assistance installing a single-node instance of elastic, see: How to Install Elasticsearch for Analytics
Elasticsearch URL:
Elasticsearch Username:
Elasticsearch Password:
Kibana v7.10
Kibana must be configured to use the above Elasticsearch index.
Supports secured or non-secured Kibana configurations
For assistance installing Kibana and running as a windows service, see:How to Install Kibana for Analytics
Kibana URL:
Kibana Username:
Kibana Password:
NLQ Services (Optional)
LUIS (v2 API)
OR
RASA v1.9
Only one NLQ service should be configured.
Supported NLQ/AI Engines:
  • LUIS- Access to a LUIS instance if using the NLQ feature
  • RASA
For more information see:
Service Endpoint:
Service Key (LUIS only):
Search Engine
Amazon Kendra
Limitations
For details see the Limitations section from Connect SmartHub to the Amazon Kendra Backend.
Kendra index name:
Kendra access key:
Kendra secret key:
Kendra region:
Click here for more details
Network Requirements
DNS entry for SmartHub site
This can be either an internal, or an external (public) DNS entry.
Entry can point to VIP / F5 / Load Balancer / other network device.
Requests should be routed to IIS on the SmartHub server over the chosen ports.
DNS name / URL for SmartHub:
SSL Certificate If running SmartHub over SSL (recommended), a signed SSL certificate for that DNS name (or appropriate wildcard cert) is required.
Certificate name:
Pass-phrase (if required):
Internal Network Connectivity
The SmartHub server must have network connectivity to the following:
  • Analytics Index
  • Search Index
  • RASA NLQ Service (optional)
Verified:
  • Elasticsearch service (see Analytics Index, above)
  • Kibana service (see Analytics Index, above)
  • Search Index
External Network Connectivity Network connectivity from the SmartHub server to the following Microsoft Azure services is required if you use the service(s):
Verified:
  • AzureAD (optional)
  • SPO / Graph API (optional)
  • LUIS NLQ Service (optional)
