ndMirror connector release notes
ndMirror connector 1.0.0.0
This release of the ndMirror connector features the following enhancements. For more information about the connector, see About the ndMirror connector.
System Enhancements
| Feature | Description |
| ndMirror connection Connection defines the how Connectivity Hub connects to your Source System (which contains your documents, graphics, etc.,). Your Connection includes identifying elements such as: URL of the BA Insight web service connector you are using, (File Share connector, SharePoint Online connector, etc.), Authentication mode, User Accounts and Credentials, Database information (for database connectors) support |
This release adds support for the ndMirror connector, allowing you to create a connection to your ndMirror documents. ndMirror is a synchronization service that allows you to automatically create a mirror copy of your NetDocuments cloud documents on a local drive. This essentially creates a local, offline backup of your documents for easier access and offline working capabilities. The ndMirror connector allows you to create a connection to your NetDocuments content, without having to call the NetDocuments API during crawls. For more information on configuring the connector, see Set up and configure the ndMirror connector. |
Fixed issues
There are no fixed issues in this release.
