Connect SmartHub to the Elasticsearch Search Engine
Note: Search engines in SmartHub are often referred to as "backends." Consider the terms interchangeable.
Use the following procedure to configure the Elasticsearch search engine.
Prerequisites
  • Elasticsearch v7.x or later must be installed.
  • If Elasticsearch is not installed, download Elasticsearch and install it.
Limitations
Note the following limitations when using an Elasticsearch search engine in your SmartHub environment:
  • Elasticsearch does not guarantee consistent ordering for documents with identical sort values (including nulls or empty values), unless a secondary sorting criterion is specified. This means that when multiple documents share the same sort value, and you do not define a secondary sort criterion, the order of their appearance in the search results may vary between query executions, leading to inconsistencies in pagination. For more details, see Paginate search results in the Elasticsearch documentation.
    • To ensure a consistent sort order, Upland BA Insight recommends that you include another field, such as a unique identifier, as a tie-breaker. In SmartHub, this can be achieved by adding a new Query Scripting Processor tuning stage with the following code:
      Query.SortList.Add(
          SortType.SortByProperty,
          "escbase_title.keyword", // this is an example of a property that can be used
          typeof(System.String),
          SortDirection.Ascending
    • Once configured, this stage must be placed before the Elastic Translator Stage in the User experience tuning section.
Connect SmartHub to an Elastic Cloud or Self-hosted Elasticsearch On-Premise Instance
Make sure that you have the following information and access for the search engine(s) that you are configuring:
  • Elastic Cloud URL
  • Access to Elasticsearch On-Premise
Add an Elasticsearch Search Engine
Procedure:
  1. Navigate to the SmartHub Administration page at http(s)://<web-app-url>/_admin
    1. For example: http://smarthub.azurewebsites.net/_admin.
  2. From the General Settings page click ADD NEW SEARCH ENGINE to add your new Elasticsearch search engine.
  3. Type: Select Regular
  4. Search Engine: Select Elastic or AWS Opensearch (for AWS-hosted Search service) from the drop-down list.
  5. Enter the search engine Name and corresponding information in the appropriate fields, as shown in the following image:
  6. (Optional): Enter these values only if you selected the Rank Based mixing algorithm that is set in the Properties for the SSA page:
    • BOOST: Enter the boost factor.
    • OFFSET: Enter the rank offset.
  7. From the Authentication Mode field, select the authentication mode for your environment's Elasticsearch type from the drop-down menu. The possible authentication modes are:
    • None
    • Basic
    • Token Based
    • API Key
  8. Depending on your selection in step 7, do one of the following:
    1. If you selected Basic, enter the account name and password for your Elastic service in the respective fields.
    2. If you selected Token Based, enter the Azure scope for your Elastic instance in the Azure Scope field.
    3. If you selected ApiKey, enter the API key for your elastic instance in the Api Key field. Your API key must be in the following format: id:api_key.
      For more information on configuring these authentication types, see Configure your Elasticsearch authentication type.
  9. Enter your credentials that are used to access Elastic Search service, based on the search engine you selected in step 4.
    • If you selected AWS-Hosted Elastic, use the following credentials:
      • AWS Access Key: Enter the access key for your AWS-hosted Elastic instance.
      • AWS Secret Key: Enter the secret key for your AWS-hosted Elastic instance.
      • Use Temporary Credentials: Use the AWS service to obtain temporary credentials
        • Expiration time: Set the expiration time of the temporary credentials. The default value is 15 minutes.
      • Authenticate via AWS Profiles:
        • Store profiles in a share AWS credentials file and use to access AWS Elastic search engine content.
        • Note: The file must be saved with an .ini extension:
          • Example: credentials.ini
        • AWS Profile name:
          • Enter AWS profile name.
          • Example: basic_profile
        • AWS Credentials file location:
          • Enter the location of AWS Credential file.
          • Example: C:\\Users\sdkuser\customCredentialsFile.ini
    • If you selected Elastic, use the following credentials:
      • Basic
        • Account: Enter the account name for your Elastic service.
        • Password: Enter the password for your Elastic service account.
      • Token Based
        • How to configure Token-based Authentication can be found here.
      Example AWS Credentials File
      [{profile_name}]
      aws_access_key_id = {accessKey}
      aws_secret_access_key = {secretKey}
  10. Modify the search engine configuration by entering your configuration settings into the Parameters field.
    See the following example code:
    Search engine configuration example
    <configuration>
        <settings>
            <setting Name='ElasticServerAddress' Value='http://localhost:9200' />
            <setting Name='Indices' Value='index1, index2' />
            <setting Name='Timeout' Value='30' />
            <setting Name='SourceMappings' Value='00000000-0000-0000-0000-000000000000#index1,index2;' />
        </settings>
    </configuration>
    1. Use the following table to specify this code:
    Parameter Description Default Value
    • Required
    • URL of your Elastic Cloud service instance.
    • Obtain this URL from your Elastic Could provider.
    Indices
    • Required
    • Specify one or more comma (,) separated indices to be used for search.
    index1,index2
    Timeout
    • Optional
    • Specify the configurable timeout of the search
    • Note: If the search takes longer than 30 seconds, the search is canceled
    30
    SuggestionFields These are the fields that you can configure if you are using the search engine spelling suggestion feature to suggest spelling alternatives for misspelled personal names, company names, and specific terms that are relevant to the user, based on your indexed data. escbase_title,escbase_fulltextcontent
    SourceMappings
    • Optional
    • A mapping between SearchQuery.SourceId and Elasticsearch indices
    • A Search Query with a matching Source ID is executed against the specified indices.
    • This option is used for performance tweaks when you have multiple search engines.
Translate queries into an Elastic search query with the Elastic Translator
After creating the search engine, two Elastic translator stages are automatically added to the Tuning categories:
  • Query Tuning stage
  • Result Tuning stage
These are search engine-specific Tuning stages and do not apply to any other search engines you have configured.
If you are using vector search, you must create a vector index in Connectivity Hub for Elasticsearch or Opensearch. For more information, see Adding AI Search capabilities to your ElasticSearch content and Adding AI Search capabilities to your OpenSearch content in the Connectivity Hub documentation.
Perform the following steps for both the Query Tuning and Results Tuning Elastic Translator stages:
  1. Click the stage name.
  2. Modify the Stage Configuration by entering your configuration settings into the Parameters field.
    See the following example code.
    Stage Configuration Example
    <configuration>
        <settings>
            <setting Name='Indices' Value='index1,index2' />
            <setting Name='RefinablePropertiesSuffix' Value='' />
            <setting Name='EnableFuzziness' Value='true' />
            <setting Name='UsePureVectorSearchAsDefault' Value='true' />
            <setting Name='MaxSearchCandidates' Value='1000' />
            <setting Name='ResultsToConsider' Value='10' />
            <setting Name='TextQueryType' Value='best_fields' />
            <setting Name='DateProperties' Value='ElasticLastUpdate' />
            <setting Name='NumericProperties' Value='FileSize' />
            <setting Name='FieldBoost' Value='' />
            <setting Name='ShowAccurateResultCount' Value='false' />
            <setting Name='BodyField' Value='FileContent' />
            <setting Name='AdditionalUrlQueryParameters' Value=' search_type,dfs_query_then_fetch' />
        </settings>
    </configuration>
  3. Use the following table to specify this code:
Parameter Optional/Required Description Default Value
Indices
Required
index1,index2
Optional
Suffix to append to the Elasticsearch field name when building an aggregation on top of it.
Timeout
Specify the configurable timeout of the search.
Note: If the search takes longer than 30 seconds, the search is cancelled.
30
EnableFuzziness
The fuzzy query uses similarity based on Levenshtein edit distance. false
EnablePureVectorSearch When this setting is set to true, the user search query will be a pure vector. When this setting is set to false, hybrid search is used. By default, this setting is set to true. This setting is only valid if you have configured an Azure OpenAI or OpenAI vector embedding generator tuning stage. true
MaxSearchCandidates This setting specifies the maximum number of matches that are returned from the vector search query. 1000
ResultsToConsider This setting specifies the number of search results that will be returned that are most similar to the search query. 10
TextQueryType
The multi_match query builds on the match query to enable multi-field queries best_fields
DateProperties
Specify the date properties that are to be used as refiners ElasticLastUpdate
NumericProperties
Specify the numeric properties that are to be used as refiners FileSize
SourceMappings
  • A mapping between SearchQuery.SourceId and Elasticsearch indices.
FieldBoost
  • Use the boost operator ^ to make one term more relevant than another.
  • The default boost value is 1, but can be any positive floating point number.
  • Boosts between 0 and 1 reduce relevance.
  • Example: escbase_author^3,escbase_fileextention^0.3
For more information on field boosting, see the Understanding field boost behavior section below.
Note that the field names should be taken from elastic, not from the property mapper.
Specify if the elastic max count of 10000 results or the accurate count is used.
  • Enabling this parameter might affect the performance
false
BodyField
Specify the field care corresponds to the body field.
  • If the elastic index is created (or updated) with Connectivity Hub v2.x the setting should be set to FileContent.
  • If the elastic index is created (or updated) with Connectivity Hub v3.x the setting should be set to escbase_fulltextcontent.
Note: If the setting is missing the default value is used.
FileContent
Specify the extra URL parameters that you want to send on the Elasticsearch search request.
  • Example: search_type,dfs_query_then_fetch
In order to send multiple parameters, they need to be separated using ";"
  • Example: param1,value1;param2,value2;
In some scenarios, an iisreset is required for Elastic Translator stage modifications are applied.
By default, Elasticsearch requests made by SmartHub use the best_fields parameter, and only the highest scoring field per document is counted. The example and scenarios below describe how the document score is calculated when this parameter is used. For other parameter types, such as most_fields, cross_fields, etc. refer to the Elasticsearch documentation.
Example
Assume document A has the term 'test' in the escbase_title, escbase_url and escbase_author fields. Elasticsearch calculates individual match scores for each field:
  • The term match in escbase_title gives a score of 0.6.
  • The term match in escbase_url gives a score of 0.5.
  • The term match in escbase_author gives a score of 0.8.
Elasticsearch returns the highest score from these three fields, resulting in the final score for the document being 0.8 from the escbase_author field only.
Scenario 1: searching for ‘test’ and boosting escbase_title^2
The score of a document that contains ‘test’ in the title can be as follows:
  • A higher score, assuming the following:
    • The term match in escbase_title gives a score of 0.6 x field boost of 2 to give a final score of 1.2.
    • In this scenario, the final score for the document will be 1.2. This score is not double as the original score was given by escbase_author (0.8).
  • Double the original score, assuming the following:
    • The term match in escbase_author gives a score of 0.4.
    • In this scenario, the final score for the document will be 1.2. This score is double as the original score was given by escbase_title (0.6).
  • The original score, assuming that when the field is boosted, it does not have the highest score:
    • The term match in escbase_url gives a score of 1.5.
    • In this scenario, the final score for the document will be 1.5, given by escbase_url.
Scenario 2: searching for ‘test’ and boosting escbase_title^0.02
  • A lower score, assuming that Document A only has the term 'test' in the title:
    • The term match in escbase_title gives a score of 0.6 x field boost of 0.02 to give a final score of 0.012.
    • The final score for the document will be 0.012.
  • The original score, assuming the following:
    • In this scenario, the final score for the document will be 0.8, given by escbase_author.
Logs
  • By default, logs appear in the directory: <SmartHub_Install_Directory>\Logging.
Operator NEAR:
  • The Elasticsearch search engine supports the operator NEAR.
  • Supported syntax:
  1. (A OR B) NEAR(5) C => "A C"~5 OR "B C"~5
  2. (A OR B) NEAR(5) (C OR D) => "A C"~5 OR "B C"~5  OR "A D"~5 OR "B D"~5
  3. (A OR "B C") NEAR(5) D => "A D"~5 OR ("B C D"~5 AND "B C")
  4. (A AND B AND C) NEAR(5) (D AND E) =>"A B C D E"~5
