About Components
A component is a part of the HP Capture and Route Server that performs a specific function. For example, the Dispatch component determines the appropriate delivery method for inbound and outbound messages on the server. Other components perform functions such as composing a message into a format appropriate for the delivery method, modifying a fax number, or determining whether a message requires previewing before processing.
All components are managed by a Windows service called the Component Manager that manages the flow of messages through the components and processing steps of a message. Except for the Compose component, you do not need a special license to run these components. Also, you cannot delete components from the server.
Note: The server may use all or only some components based on your configuration.
The following table describes each component installed with the server.
Component |
Description |
The Barcode extractor allows the server to read and process barcoded cover sheets (or separator pages) generated by the CA Records Manager web client. |
Extracts billing data for CostRecovery. |
Collection Locator component |
The Document Collection Key property acts as a locator key to help the Data Extractor component identify and route documents to the correct Document Collection. |
Converts messages and documents into the appropriate format for delivery. |
Allows the server to read and process barcodes and identify values in scanned document pages. |
Holds outbound messages in the sending queue until they can be delivered by the appropriate connector or delivery mechanism. |
Determines the appropriate delivery method for all messages—inbound and outbound. |
Detects, decodes, and applies Embedded Directives. |
FaxCenter Routing component |
Holds inbound faxes that reside in FaxCenter until a FaxCenter user routes them to the appropriate recipients. |
Looks up a DID or DTMF number and finds the appropriate recipient for an inbound fax. |
Performs archiving and cleanup functions on the server. |
| Generates and sends notification messages from the server to the email accounts of message senders and recipients when important events occur during the processing of a message. | |
Determines whether a message needs to be previewed before the server continues processing it for delivery. |
| Holds a message that is waiting to be previewed. | |
Recipient Registration Manager component |
Determines whether the recipient of a secure fax has registered with the server. |
