About Notification Component
The Notification component generates and sends notification messages to message senders, approval managers, and recipients when important events pertaining to messages occur on the HP CR server.
There are many ways you can customize notification messages to suit the needs of your company. Notification messages are generated from templates that you easily edit.
The Notification component is a required component and cannot be deleted. You can have up to four instances of this component. Do not modify its settings unless Technical Support instructs you to do so.
Configuring the Notification component
The Notification component delivers a notice about the status of a message to the person who sent the message. Notification is only sent for outbound messages or messages that originate within the server.
How the Notification component works after installation
Notification is set up by default. No additional settings are required.
Accessing the Notification component
To access the Notification component
  3. Double-click Components. The Components are listed in the details pane.
  4. Click Notification to open the Properties dialog box.
About Notification Messages
Customizing Notification Messages
About Notification Message Templates
About Inbound Fax Message Notifications
Adding Notification Message Thumbnail Image
