Customizing Notification Messages
There are several ways you can customize notification messages.
Customize the content and the subject line of all notification message templates to suit the needs of your company.
Modify the notification message template so that the notification message contains a link to the Web Client where the recipient can view the message. For instructions, see Adding Web Client link and Excluding attachment.
Note: By default, the server sends notification messages to inbound message recipients without the inbound message attached. Instead, the notification message contains a link to the Web Client where the recipient can view the message.
Modify the notification message template so that the notification message from the server displays a thumbnail image of the first page in the body of an outbound message. For instructions, see Adding notification message thumbnail image.
Specify the sender of notification messages on the server. (If you do not specify the sender, the sender will be displayed as "MessageServer".)
Server notification message templates
Template |
Description |
EmbeddedDirectiveBatchFailure.OMTPL |
Notifies the sender when the processing of a batch fails. |
EmbeddedDirectiveBatchFailure-Subject.WTX |
Subject line text for EmbeddedDirectiveBatchFailure.OMTPL |
EmbeddedDirectiveUsed.OMTPL |
Notifies the sender when a single use Embedded Directive has been used |
EmbeddedDirectiveUsed-Subject.WTX |
Subject line text for the EmbeddedDirectiveUsed.OMTPL |
OMNotification-Failure.OMTPL |
Notifies the sender when processing of an outbound message fails |
OMNotification-Failure-Subject.WTX |
Subject line text for OMNotification-Failure.OMTPL |
OMNotification-Incoming.OMTPL |
Notifies recipient when the server routes an inbound message to him; the server attaches the message to the notification message; the server delivers this notification to the email account of message recipients |
OMNotification-Incoming-Subject.WTX |
Subject line text for OMNotification-Incoming-Subject.WTX |
OMNotification-Incoming-Web.OMTPL |
Notifies recipients when the server has routed an inbound message to them; the server attaches this message to the notification message; the server delivers the notification to the recipient's Inbox in the Web Client |
OMNotification-Incoming-Web-Subject.WTX |
Subject line text for OMNotification-Incoming-Web.OMTPL |
OMNotification-Preview.OMTPL |
Notifies the sender when an outbound message is available for preview |
OMNotification-Preview-Subject.WTX |
Subject line text for OMNotification-Preview.OMTPL |
OmNotification-ScanSheet.OMTPL |
Notifies the Desktop user when an outbound message has been processed and delivered to its final destinations |
OmNotification-ScanSheet-Recipient.OMTPL |
Comments created by the Desktop user for the recipient |
OmNotification-ScanSheet-Subject.WTX |
Subject line text for OmNotification-ScanSheet.OMTPL |
| ScanToMe.OMTPL | Notifies the sender when a Scan to Me job is processed. |
| ScanToMe.WTX | Subject line text for ScanToMe.OMTPL |
OMNotification-Success.OMTPL |
Notifies the sender when the server dispatches the outbound message to its final destination. Note: It is recommended that you set a value that is greater than 40% for %FAX_PAGE1% variable (or %PAGE1% variable) when you customize the template. Otherwise, the notification thumbnail that is generated is unreadable as it is too small. For information on the variables, see List of template variables (in alphabetical order) |
OMNotification-Success-Subject.WTX |
Subject line text for OMNotification-Success.OMTPL |
OMNotification-Wait.OMTPL |
Notifies the sender when the processing of the outbound message is delayed |
OMNotification-Wait-Subject.WTX |
Subject line text for OMNotification-Wait.OMTPL |
Sample cover page |
Sample cover page |
About Notification Message Templates
About Inbound Fax Message Notifications
Adding Notification Message Thumbnail Image
