The basic processes involved in the Capture OnTheGo Workflow
PlanetPressĀ® or PReSĀ® Connect is an extremely flexible solution that lets you do almost anything you want with your data. So although the three basic processes explained in this section are required to enable a Capture OnTheGo solution, you may add as many plugins and processes as you like to customize a solution that perfectly suits your needs.
The three basic processes are:
- The process that makes a document available to Capture OnTheGo App users, see The process that publishes a Document.
- The process that authenticates and replies to document requests from Capture OnTheGo App users, see The process that replies to document requests from Capture OnTheGo App users.
- The process that receives data from Capture OnTheGo App users, see The process that receives data from Capture OnTheGo App users.
