Review Typical Concepts
This topic considers OL Connect Workflow concepts and how they can be achieved in OL Connect Automate.
Workflow Concept Automate Resolution Additional Information
Creating endpoints/accepting HTTP requests (NodeJS Server Input or Client Input)
http in node
Supports standard HTTP methods. Allows both URL and Query parameters.
Data Repository
The Data Repository is a permanent structure to store data that can then be reused, modified or augmented at a later time, by different processes.
Use an external database.
In many OL Connect AutomateAutomate projects, it’s useful to persist information outside of the running flows, especially when data needs to be shared between flows, reused later, or presented in a Dashboard. While OL Connect Workflow provided a built-in Data Repository, in OL Connect Automate this functionality can be implemented more flexibly, using a standard database. See Use External Databases for more information.
Debugging step-by-step
Debugging in OL Connect Automate follows a different model than Workflow.
Automate favors visibility and repeatable execution over step-by-step inspection.
Rather than walking through a process one step at a time, flows are designed so that execution paths are easy to see and test inputs are easy to replay. Over time, many users find this approach faster and more reliable, especially as flows evolve and need to be retested regularly.
The canvas model for flows, scripting feedback in the editor, and built-in testing patterns remove much of the need for step-by-step testing.
See Debug without a debugger for more information.
Dynamic resource names
(template, datamapper, and preset names)
change node or function node
Set the respective msg property (see the documentation of the respective nodes).
Lookup in Microsoft Excel Documents
In Workflow, the Lookup in Microsoft Excel Documents action task is used to enrich a job’s Metadata by querying an external Excel spreadsheet. Based on one or more existing Metadata values, Workflow performs a lookup against the spreadsheet and retrieves matching data, which can then be added to the Metadata or used to append to or replace existing fields.
template node, storing the spreadsheet in JSON format. Use standard JavaScript in the function node for lookups Store JSON data in a flow variable using the template node and perform a lookup in JavaScript using the function node.
Merge PDF
The Merge PDF Files Input task (formerly named "Concatenate PDF Files") captures all PDF files in a given folder and merges them into a single PDF file.
function node
pdf-merger-js module
Use a function node and the pdf-merger-js. module. This method may come in handy when merging a banner page with OL Connect generated content.
NodeJS Server input Direct response
read file or template node
PDF Splitting
Splitting PDF data into multiple files is a common technique used to separate documents and then process each one individually.
Use the document boundary options in data mapping configurations in OL Connect
OL Connect Automate use the document splitting capabilities of OL Connect Server. This is handled through the boundaries settings of a data mapping configuration. This configuration can be used in the Data Mapping or Document Mapping nodes. For more information read the Split PDF documents using OL Connect article. This technique can be applied to other incoming print-ready streams.
Scheduling processes
The Workflow scheduling settings let users control when processes run by specific times, days, or months.
inject
function node
The inject node allows a flow to be triggered at defined intervals, for example, every 15 minutes, once every 24 hours, or between specific times on selected days. This configuration covers most common scheduling scenarios.
In OL Connect Workflow, additional scheduling options are available, such as running a process during the first week of the month. While the inject node does not include this functionality by default, it can be implemented by adding a function node.
Startup Script
Used to populate global variables from a file, and perform specific tasks when starting workflow.
Environment variables and/or inject node, depending on the purpose of the script.
To populate global variables, see Use environment variables in flows.
Use the inject node in a startup flow to perform tasks, such as deploying resources from OL Connect. See Automated deployment for details.
Subprocess
Subprocesses are special processes that can be called by any other process. Subprocesses act exactly as subroutines in programming languages, allowing users to reuse existing processes by sharing them to the whole configuration file.
subflows or link node
Primary uses cases: reuse or visually group logic. Subflows primary use case is code reuse. Use the Link node to visually group logic on the flow tab (pros: have all logic in one view, easier to debug). You can also link between flow tabs using Link Call nodes, which integrate seamlessly and are generally more efficient than subflows for organizing simple or localized logic.
System variables
System variables are standard variables, created and managed directly by OL Connect Workflow. These variables are read-only and cannot be modified. They provide information about the job, process, and OL Connect Workflow environment.
JSONata in change or inject nodes
function node
There is no direct equivalent of the System Variables as seen in OL Connect Workflow, but there are various ways to create similar values using the JSONata expression language and the powerful function node (for example, to generate uuids). For more information, see System Variables.
Text condition branching
Text conditions are a core technique for controlling how messages move through a flow. In OL Connect Workflow this was handled through the Text Condition or Run Script tasks.
switch or function node
The switch and function nodes provide functionality similar to their counterparts in OL Connect Workflow.
The switch node offers standard conditions such as equals, less than, contains, and regex, while the function node provides more flexible, JavaScript-based control over text conditions. In OL Connect Automate, conditions are not limited to simple true/false decisions: nodes can have multiple outputs, each representing a different condition, making flows easier to read and follow.
See Text condition branching for more information.
