Additional Barcode Options
When adding Barcodes in the Additional Content page you can select from a series of predetermined Barcode types.
To create dynamic barcodes, Meta Data options must first have been set. Metadata fields are required to create the association between the dynamic data used in the print run and the barcode.
The options for each of these types are described on the following pages:
