find()Method of the In PlanetPress Connect 1.8 and previous versions, the DataMapper's
boundaries.find() function returned the region searched within PDF files, whereas for text files it returned the exact region where the text was found. In 2018.1 this was changed so that boundaries.find() on PDFs would return the exact region where the text was found, the same as for text files. However, it was subsequently found that this could cause issues with previously created templates using the function on PDF files. Consequently, this change was reverted in 2018.1.1. find(stringToFind, in_Region)Finds the string stringToFind in a rectangular region defined by in_Region. stringToFind String to find. in_Region The in_Region region can be created prior to the call to find() with the region.createRegion() method. It depends on the type of data source how a region is defined; see createRegion(). When used to search through a Text file, the Use ExampleThis script sets a boundary when the text TOTAL is found on the current page in a PDF file.
