7.67.52015-05-06
Page Properties
To view or edit properties using the Object Inspector:
  1. In the Structure area, select the page whose properties you want to view or edit.
  2. In the Object Inspector, make any necessary modifications to the properties.
To view or edit properties using the Page properties dialog box:
  1. In the Structure area or in the Page area, select the page and double-click on it to display the Page properties dialog box.
  2. Use the Page properties dialog box to view and/or edit the page properties.
  3. In the Page properties dialog box, click OK.
The properties of a page are as follows:
Basic attributes
Paper handling
Paper input/output
Advanced paper handling
Overlays: In order to use overlays, you need to have at least one defined. See Add or Remove Overlays.
Attachments: To use attachments, see Associate Attachments with a Page.
PlanetPress Talk before: enter PlanetPress Talk code that you want to execute before the page executes
PlanetPress Talk after: enter PlanetPress Talk code that you want to execute after the page executes.
