7.67.52015-05-06
Set Up a Document
You can view or edit the properties of a document using either the Object Inspector or the Document properties dialog box.
To view or edit properties using the Object Inspector:
  1. In the Structure area, select the document icon.
  2. In the Object Inspector, make any necessary modifications to the properties.
To view or edit properties using the Document properties dialog box:
  1. Double-click on the Document node to display the Document properties dialog box.
  2. Use the Document properties dialog box to edit the document properties, if necessary.
  3. In the Document properties dialog box, click OK.
The properties of a document are as follows:
Basic Attributes
Paper Handling
Advanced Paper Handling
Compilation Options
For help creating documents that use Fiery® FreeForm™ or Freeform 2 features, see FreeForm Caching or FreeForm 2 Caching. For help creating a document in VPS or VDX format, refer to VPS Caching.
Resource Options
Binding
Attachments (see also Add PostScript Attachment Resources)
Job Infos ( aka jobinfo or jobinfos )
Scan code settings
Metadata
PlanetPress Capture (see also Capture Field Object)
PlanetPress Talk before: Enter PlanetPress Talk code that you want to execute before the document executes
PlanetPress Talk after: Enter PlanetPress Talk code that you want to execute after the document executes.
