7.67.52015-05-06
Text and Box Object
Text and Box objects are essentially the same object. The Box object is offered as a separate menu in the ribbon for convenience - it gives you automatic starting options for borders that appear around the text object. On the other hand, the Text object will not show any borders by default.
The following properties tab apply to the Text and Box options:
Borders
Borders are applied either through the Settings pre-defined border settings, or manually. To define the borders manually, start by choosing the color, width and style of the border you want to apply, then click on the appropriate button to add the border you want. To remove a border, click on the - None - line style then click on the border button you want to remove.
Color
Text
This is the primary settings tab for the Text and box object. It contains different sections that help you manipulate the text in the object itself.
Menu:
