7.67.52015-05-06
Capture Field Object
The Capture Field object is used to create input fields for use with the Anoto Digital Pen in a PlanetPress Capture workflow. A document containing capture fields is called a capture ready document, or simply a capture document. Any capture document must pass through the Capture Fields Generator action task in PlanetPress Production in order to be printable.
For information on PlanetPress Capture implementations, environment considerations, activation and more, please check the PlanetPress Workflow User Guide - PlanetPress Capture
PlanetPress Capture Fields cannot simply be inserted into an existing document as-is and expected to work properly, efficiently or consistently. In order to design a document with Capture Fields, you must review and understand the Critical PlanetPress Capture Implementation Restrictions.
In addition to the common object properties, Capture Field objects have the following properties:
Capture Options tab
Disable Rewriting fields will only work if the Fail if new ink is found on non-rewritable fields option is selected in the Capture Field Processor action task of PlanetPress Workflow.
Considerations
There are some important considerations when using the capture field object in a PlanetPress Design document:
