8.18.32016-03-14
Create Web Content
The Create Web Content action task generates the output of the HTML Context of a specified template and returns the HTML code to PlanetPress Workflow for further processing and return to the requester. Generally, this task is placed within an HTTP Server Workflow.
This task must receive the information regarding a valid Record Set. This can be the output of the Create Record Set task, or a Record Set retrieved using the Retrieve Entities task.
For a single record, this task generates the output for the HTML Context of the specified template. Any external resources such as images, css stylesheets or javascript files, are also produced and put aside on the OL Connect Server component.
The task outputs HTML code as a job file. Within this HTML code, references to external resources point to the local OL Connect Server and are served to the requester directly when the HTML file is opened in a browser.
Properties
The Create Web Content Action Task properties are as follows:
Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs send through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences. Note that defaults are not used unless the configuration is sent to the Workflow service.
Common Errors
Comments Tab
