Retrieve Items
The Retrieve Items Action Task locates and extracts items from the OL Connect Database so they can be used with further tasks. The items are retrieved using a set of conditions working together. Since this task can retrieve items at any level, it can be used to generate metadata used in multiple tasks.
The task requires no input file, but any input information such as metadata, job information or data file can be used to specify which items to retrieve.
The task requests the items on the OL Connect Server using the conditions set in the task properties. Only the condition information and the return metadata are exchanged.
The task outputs metadata that is equivalent to the appropriate task that would normally create the items (see the task properties for the list).
Properties
The Retrieve Items Action Task properties are as follows:
- Entity to retrieve: Use the drop-down to select which items to retrieve.
- Record: Retrieves one or more Records, whether or not they are part of a Record Set. Output similar to the Create Record Set task.
- Record Set: Retrieves one or more Record Sets, including all their records. Output similar to the Create Record Set task.
- Content Item: Retrieves one or more Content Items, whether or not they are part of a Content Set. Output similar to the Create Print Content or Create HTML Content Set tasks.
- Content Set: Retrieves one or more Content Sets, including all their content items. Output similar to the Create Print Content task.
- Job: Retrieves one or more Jobs, including all their content items ready to be printed. Output similar to the Create Job task.
- Conditions:
- Add a condition: Click to add a new condition line. This adds the line to the current condition level, by default with an AND operator.
- Switch conditions: Click to swap two conditions on the same level, or two groups of conditions.
- Delete the selected condition: Click to delete the currently selected conditions in the list.
- Clear the rule: Click to delete all rules in the list. Note: This cannot be undone.
- Import a rule: Click to open the Browse dialog and load a Rules file. This will load its rules into the list.
- Export the rule: Click to open a Save dialog and save the Rules file to disk.
- Rule Viewer: Displays a text-based view of the condition using operators and parentheses.
- Output Type group:
- Output IDs in Metadata: Select to only output minimal metadata containing the entity IDs.
- Output records in Metadata: Select to output IDs as well as record details in the metadata, useful for further sorting and filtering of the metadata.
Commingling/Batching Tab
Commingling (available only with the appropriate license) is a method by which Print Content Items are merged together to create mail pieces going to each recipient. For instance, retrieving a letter, an invoice and a notice within the same mail piece, which presumably could be added within the same envelope. Batching is the same principle when all the Print Content Items are generated using the same Template file. This tab is only available if the "Content Item" option is selected in the General Tab's "Entity to retrieve" drop-down. To modify any of the following options, click in the Parameters box and then click the [...] button that appears.
- Document contents: Defines the Document ("Mail Piece") level and how they are built.
- Pick items based on: Use the [...] to open the Pick Parameters dialog and define how to pick which items will be placed in each document. Content items picked using this method will be part of the same mail piece.
- Sort items based on: Use the [...] to open the Sort Parameters dialog and define how Content Items are sorted within the mail piece.
- Group contents: Define the Group level (for example, a Mail Route), or how to group mail pieces together in groups.
- Pick items based on: Use the [...] to open the Pick Parameters dialog and define how to pick which documents will be placed in each document Group. groups are often used to separate mail routes, provinces, or cities.
- Sort items based on: Use the [...] to open the Sort Parameters dialog and define how Documents are sorted within the Group, for example by ZipCode.
Connect Proxy Tab
This tab is common to all OL Connect tasks and defines where to process the jobs send through these tasks. When these fields are empty, they use the defaults set in the OL Connect User Options page of the preferences. Note that defaults are not used unless the configuration is sent to the Workflow service.
- Connect Proxy Address: Enter the machine name or IP Address where the OL Connect Server resides.
- Port: Enter the port to use to communicate with the OL Connect Server. Default: 9340
- Username: Enter the username expected by the OL Connect Server.
- Password: Enter the password expected by the OL Connect Server for the above username.
By default, any action task, branch, splitter or condition that generates an error will simply be ignored, and the task just under it (not within a branch) will be given control of the job file without any modification. Any initial input task that generates an error will stop the process from running as a whole, and output tasks will not generate output. The On Error tab can be used to overwrite the default behaviors.
- Send to Process: Check this option to send the job file to an error management process.
- Error Process drop-down: Enabled only when the Send to Process option is checked. Lists any process of which the initial input task is the Input Error Bin task.
- Action Group: This group is disabled in the initial input tasks and defaults to Stop Process. In all other tasks where the On Error tab is present, the following options are available:
- Ignore: The task is ignored as if it did not exist, and the job file is passed on to the next task in the process.
- Stop Branch: If the task is in a branch of the process, the branch is stopped and the job file is returned to the process after the branch. The branch will not produce any output.
- Stop Process: The process is stopped and no more processing is done. No further output is produced.
- Log Message: Check this option to enable logging a custom error message in the PlanetPress Suite Workflow Tools' log file.
- Message: Enabled only when the Log Message option is checked. Enter a message that will be logged in the PlanetPress Suite Workflow Tools' log file. You can use any variables available in PlanetPress Workflow to customize the message.
- Store the message in variable: Select in which jobinfo, local or global variable you want to store the message content.
- ID: Enter an error ID. This ID will be visible in the Windows Event Viewer. However, the ID is not visible in the PlanetPress Suite Workflow Tools' log file.
- Store the ID in variable: Select in which jobinfo, local or global variable you want to store the error ID.
- Reset to defaults: Resets all options in this tab to their default values.
Common Errors
Comments Tab
The Comments tab, added in PlanetPress Suite 7.5, is common to all tasks. It contains a single text area (Task comments) that lets you write comments about the task. These comments are saved when the dialog is closed with the OK button, and are displayed in The Task Comments Pane.
