Edit a Custom Field
Once a custom field has been created, custom field details can easily be edited.
1. Click Custom Fields
Click Custom Fields
  • On the Icon Bar click the Admin button.
  • Click Configuration to expand the menu, then click Custom Fields.
2. Select Custom Field
Select Custom Field
  • Click the name of the custom field that you want to edit.
3. Edit Custom Field
Edit Custom Field
  • Edit custom field details as necessary.
Note: Once created, a Custom Field Type cannot be changed (i.e., if it was created as a date field, it cannot be changed to a numeric field).
Note: To include the Custom Field in a metric template, select Metric from the Other Assoc drop-down. For an explanation of custom field limitations, see section 3.1
  • Click Save.
3.1 Custom Field Limitations
There are limitations to custom field settings if they are to be used as Metrics. Custom Fields cannot include the following settings:
  • Apply Permissions
  • Required (default)
  • Locked (default)
If any of these are active in a custom field, and it is selected as a metric, the user will receive an error message detailing which settings are not supported.
4. View Custom Fields
View Custom Fields
  • View the updated Custom Field in the list.
