What are the Views and Field Definitions in Upland Analytics?
The Views have been created to simplify the data selection process, allowing for easier report creation and less time consumed trying to understand complex data models. Below you will find links to available Views with detailed definitions for each of the Fields.
Note: Views and Fields visibility can be customized; some may not appear in all instances. Please contact your administrator to add any listed that are not currently visible.
All Work Data Source
Discussion Item Data Source
Document Version Data Source
Documents Data Source
Gated Projects Data Source
Issues Data Source
Measure Entries by Work Data Source
Measure History Value by Work Data Source
Metrics Data Source
Most Recent Status Report Data Source
Program Metrics Data Source
Risks Data Source
Team Member Data Source
Visual Program Hierarchy Data Source
What Views and Fields are available in the Work History related Data Source?
Access Upland Analytics Help Center
