Set Prior to/After End of Period Reminder Options and Validate Dependency Sort Order
This article details how to configure reminder options related to timesheet periods, including setting notification days before and after the period end based on your organization’s period type. It also covers the importance of maintaining the correct dependency sort order for fields in the Assignments section to ensure data displays properly and workflows function smoothly.
Note:
The Complete Timesheets [x] day(s) prior to the end of period and Complete Timesheets [x] day(s) after the end of period reminders also trigger when a Timesheet enters a rejected Sub-Workflow State.
Example: When a Project Manager rejects a specific Timesheet (a partial rejection), the Timesheet moves into a Sub-Workflow State requiring user action. The user must correct and resubmit the Timesheet. In this case, the configured reminders are also sent to notify the user that their Timesheet needs attention.
Prior to the End of the Period Options:
The number of days you can select depends on the Period Type configured for your timesheet template:
- Weekly period: 0 to 7 days
- Bi-weekly period: 0 to 14 days
- Semi-monthly period: 0 to 15 days
- Monthly period: 0 to 31 days
Note: The number of day(s) should be updated based on the period type you have.
After the End of the Period Options:
Similarly, the range of days after the period end varies by Period Type:
- Weekly period: 1 to 7 days
- Bi-weekly period: 1 to 14 days
- Semi-monthly period: 1 to 15 days
- Monthly period: 1 to 31 days
Validating to Ensure Correct Dependency Sort Order
When saving your changes, the system validates that the fields shown in the Assignments section follow the correct dependency sort order.
The dependency order is as follows:
Clients |
Projects |
Tasks |
Assignments |
Example: If both Projects and Clients are selected, the Client column must appear before the Project column.
