Delete a Timesheet Template Assignment
This article explains how to remove a Timesheet Template assignment associated with a group, resource type, role, security profile, site, or individual user, helping you keep template assignments up to date and accurate.
. - From the Navigation Menu click Timesheet.
- From the available options select Timesheet Templates.
- From the Timesheet Templates list that displays, click the Name of the Timesheet Template you wish to access.
- From the Assignments tab of the Timesheet Template Edit page you can delete Assignment(s) by following one of the following steps:
- Delete a Timesheet Template Assignment
- Click the Delete
button. - Confirm deletion by clicking Yes.
- Delete Multiple Timesheet Template Assignments
- Select the Timesheet Template Assignments you wish to delete.
- Click the Delete
button located in the table header area. - Confirm deletion by clicking Yes.
- By selecting all Assignments
- Select the selection box next to the delete button in the table header. This will select all Timesheet Template Assignments.
- Click the Delete
