Create a KPI
1. Create Report
Access the Create Report modal by:
- Click the Create button on the Main Menu Bar.
- Then select Report from the menu.
2. Select your Data Source
- Select your data source from the list of available data sources to get started.
- Click Next to continue.
3. Add a Report Title
- Click on the Add report name box and type the name of your report.
4. Select a Report Type
- Click the arrow button next to Select report type.
- Select KPI from the list of available report types to get started.
5. Select a Folder
- Click the Save In arrow to view and select an available folder where your graph will be saved.
- Do one of the following to make your selection:
- Choose or create folder: Enter values in this box to filter and find the folder where your graph will be saved.
- Click the arrow and select Add New Folder to create a new folder where your graph will be saved. See Create a Folder below.
- In the Folder Name box, type your new folder name.
- Select the desired Parent Folder from the list.
- Select your Folder Visibility:
- Public: By default, this option is selected. This option allows your folder to be viewed by all users.
- Private: This option will allow you to hide your folder from other users.
- Share: This option allows you to set your folder to be viewed by specific user(s).
- Click Create to create your new folder or Cancel to return to the previous page.
6. Filter or Search for Data Fields
- Select the desired Filter to apply to the list of available Fields. The available options are:
- All Fields
- Dimensions
- Measures
- Date
- Start typing in the Search item box to begin searching for available Fields.
- You can alternate between Fields and Custom Fields by clicking on either one of the tabs. Tip: For more information on how to create and use Custom Fields please refer to: Create and Use Custom Fields
7. Select your Data Field(s)
- Measures: Drop up to two numeric Fields in the following order:
- One Field that will show the main number of the KPI. Use Custom Fields to show values with thresholds.
- One Field that will show additional information if need be.
8. Add a Filter (Optional)
- Click the Ellipsis button of a Field added to Data Points, Data or Group By sections.
- Select Filter Options from the context menu.
9. Add a Pivot (Optional)Add a Pivot (Optional)
- Click the Ellipsis button of the Field(s) added.
- Select Pivot Measure from the context menu.
- Begin typing the Alias name of your column in the Column Name box .
- Select one of the following:
- Multi Column: By default, Multi Column is selected. Presents your pivot value within multiple columns.
- Single Column: Presents your pivot value in one column.
- Click or type the desired Pivot on Dimension.
- Click or type the desired measure.
- Click or type the desired Group By.
- Click the Add button to add a new Pivot option.
- Click Apply to save your changes and return to the previous page. Alternately you can Cancel your changes and return to previous page.
10. Preview Report
- Click the Settings icon to configure the KPI settings.
- Values
- Currency Formatting: The following option are available:
- Inherited: Selected by default.
- With Decimals
- Without Decimals
- Thousands
- Thousands with decimals
- Millions
- Millions with decimals
- Volume Formatting: The following option are available:
- With Decimals
- Without Decimals
- Thousands
- Millions
- Preview: Displays a preview of the selected formatting.
- Save: Click to save your changes.
- Display Options: The following options are available for the selected chart:
- Chart Type: Select the type of chart to display: Bar or Pie.
- Default Color or Override Color: Select the color for the bar chart.
- Select Yes/No for Standard Template.
- Select Yes/No for Show in Upland WorkCenter to allow the report to display in Upland WorkCenter.
- Select your Report/Chart Visibility.
- Public: By default, this option is selected. This option allows your graph to be viewed by all users.
- Private: This option allows your graph to be viewed by you only.
- Share: This option allows you to set your graph to be viewed by a specific user(s) or role(s) and give permissions. The Shared With field displays:
- Click the Select a value field and select the user(s) or role(s) to share your graph with.
- Click the arrow and select the permission for each user or role. The available options are:
- Can edit and view: The default
- Can view
- Click Add.
- Click Save to save your changes.
This tab displays only if you have added a chart to your layout.
11. Save Report
- Click Save to open the Save context menu
- Choose one of the available Save options:
- Save: Selecting this option will save the report without exiting the report edit page.
- Save as copy: Selecting this option will save a copy of the report. You will need to rename the report in the Navigation Menu.
- Save & Close: Selecting this option will save the report and close the report edit page. The report will then run.
- Save & send by email: Selecting this option will save the report and close the report edit page. A modal window will then give you the options to send the report. For more information refer to Email a Graph/Chart.
- Save & Create new: Selecting this option will save the report and close the report edit page giving you the option to create a new report.
Menu
