Graphs and Charts
Graphs and charts in Upland Analytics are easy to create and understand. There are several graph and chart types available for selection when creating a report.
Report |
Pivot |
Bar |
Stacked-Bar |
Line |
Pie |
Radial Gauge |
Scatter |
Bubble |
Heatmap |
Radar |
Area |
Waterfall |
Sunburst |
KPI |
Gantt |
Control |
Box Plot |
Pareto |
Report
Reports are most commonly used to summarize your data fields within a summary or pivot format.
The following Dimensions are available for a Summary Format:
- Columns
- Filters
For more information on how to create a report, click here.
Pivot
A Pivot table is an interactive way to quickly summarize large amounts of data.
The following Dimensions are available for a Pivot Format:
- Columns
- Filters
- Rows
- Measures
For more information on how to create a Pivot table, click here.
Bar
Bar graphs present your data in either horizontal or vertical bars to show comparisons of your data fields.
The following Dimensions are available for this Display Format:
- Data Points
- Data
- Filters
For more information on how to create a Bar graph, click here.
Stacked-Bar
Stacked-Bar charts allow you to compare your data fields to the whole and are divided into categories.
- Data Points
- Data
- Stack Data By
- Filters
For more information on how to create a Stacked-Bar chart click here.
Line
Line graphs display your data within a series as points connected by straight line segments on two axes and helps determine the relationship between two sets of values.
- Data Points Data
- Data
- Group By
- Filter
For more information on how to create a Line graph click here.
Pie
Pie charts display your data in percentages of several data fields divided in several portions to show related information.
- Data Points
- Data
- Filters
For more information on how to create a Pie chart click here.
Radial Gauge
Radial Gauge charts are presented in a semi-circular scale with a needle indicator that display the maximum value of your data or key performance indicators (KPIs).
- Data Points
- Data (Pointer)
- Data (Range)
- Filters
For more information on how to create a Radial Gauge chart click here.
Scatter
Scatter graphs display two data fields as a collection of points each having one coordinate on the horizontal axis and one on the vertical axis.
- Data Points
- Data (X-axis)
- Group By (Y-axis)
- Filters
For more information on how to create a Scatter graph click here.
Bubble
Bubble charts display the relationship between three data fields.
- Data Points
- Data (X, Y, Size)
- Filters
For more information on how to create a Bubble chart click here.
Heatmap
Heatmaps are an interactive display that is used to view the total cost consumption in different sizes and colors.
- Data Points
- Data (size of rectangle)
- Group By (color of rectangle)
- Filters
For more information on how to create a Heatmap click here.
Radar
Radar charts display a series as a circular line or area.
- Data Points
- Data
- Filters
For more information on how to create a Radar chart click here.
Area
Area charts are basically a line chart, but the space between the x-axis and the line is filled with a color or pattern. It is useful for showing part-to-whole relations.
- Data Points
- Data
- Group By
- Filters
For more information on how to create a Area chart click here.
Waterfall
Waterfall charts are a type of bar graph, similar to a Stacked-Bar chart except that bars don't overlap and the origin of each bar starts where the previous bar ended, allowing negative values to be readily depicted.
- Data Points
- Data
- Filters
For more information on how to create a Waterfall chart click here.
Sunburst
Sunburst charts are ideal for displaying hierarchical data. Each level of the hierarchy is represented by one ring or circle with the innermost circle as the top of the hierarchy. A sunburst chart without any hierarchical data (one level of categories), looks similar to a doughnut chart.
- Data Points
- Data
- Filters
For more information on how to create a Sunburst chart click here.
KPI
Key Performance Indicators (KPI) are measurable values that demonstrate how effectively a company is achieving key business objectives. Organizations use KPIs to evaluate their success at reaching targets. Selecting the right one will depend on your industry and which part of the business you are looking to track. Each department will use different KPI types to measure success based on specific business goals and targets.
- Measures
- Filters
For more information on how to create a KPI click here.
Gantt
Gantt charts are a type of bar chart that illustrates a project schedule. This chart lists the tasks to be performed on the vertical axis, and time intervals on the horizontal axis.
- Data Points
- Filters
For more information on how to create a Gantt chart, click here.
Control
Control charts are used to filter out the probable noise (inherent variation or common cause) from the potential signals (nonrandom variation or special cause). From this, you know when and where to take action on a process.
- Data Points
- Data (X-Axis Group and Y-Axis Data Set)
- Filters
For more information on how to create a Control chart click here.
Box Plot
Box Plot charts present information from a five-number summary. It does not show a distribution, but is especially useful for indicating whether a distribution is skewed and whether there are potential unusual observations (outliers) in the data set. Box plots are also very useful when large numbers of observations are involved and when two or more data sets are being compared.
Box plots are ideal for comparing distributions because the center, spread, and overall range are immediately apparent.
- Measures
- Fields
- Filters
For more information on how to create a Box Plot chart click here.
Pareto
Pareto charts contain both bars and a line graph, where individual values are represented in descending order by bars, and the cumulative total is represented by the line.
- X-Axis and Y-Axis Data Sets
- Filters
For more information on how to create a Pareto chart click here.
