About WebApps
WebApps is a highly-customizable version of the former legacy Web Client.  Administrators can assign applications like Inbox, Create Distribution, Mobile Reservations and more to customized WebApps profiles. The profiles are applied to specific user groups and define what user group members can see or do. The Server Administrator > Configuration > WebApps node is used to configure the WebApps UI (User Interface).
Creating a WebApps Client profile
You can create a profile by using Server Administrator > Configuration >WebApps.
To create a new profile
  1. In the Server Administrator, go to the Configuration node and right-click WebApps > New > Profile. The New Profile Properties screen appears.
  2. Enter a profile name, and optionally, a description.
  3. Go to the Applications tab, click Add and (one at a time) select the applications of interest from the various options in the drop-down menu.
  4. For example, click Add > Messages > Inbox. The Inbox Application Properties screen opens. Here you can further refine specific Inbox properties as needed.
  5. Click OK to exit the application's Properties screen. When you return to the New Profile Properties screen, you will see the selected application added to the list.
  6. In the Features tab, click Add and select any feature you want to associate with the profile.
  • Options include: DocumentLink, Favorites, PrinttoWeb, ScantoWeb, and SendtoWeb.
  1. As it does with Applications, a Properties screen appears for any feature you select. You can further refine a feature’s characteristics in its Properties page.
  2. Click OK to exit the Features Properties screen, and click OK again.
Your new profile appears in the list.
Note: To edit properties of an existing Profile, right-click the profile of interest and select Properties to access Profile Properties.
Applying a WebApps profile to a user group
You can apply a WebApps profile to a user group by using Server Administrator > Configuration > Groups.
To add a profile to a user group
  1. Go to Configuration > Groups, right-click the group of interest and select Properties.
  2. In the Group Properties screen, click Clients > Web.
  3. Make sure Enable members of this group to use the following web view is selected.
  4. Click the Profile drop-down list and select the profile of interest. Click OK.
The user group is updated to use the profile in the WebApps user interface.
MyFiles
AddressBook Integration
WorkSite Web Extensions
Customizing WebApps Link
