About Routing Sheets
                                            Routing sheets always contain Embedded Directives information.
When the server generates a routing sheet on demand for an
Routing Sheets are the result of two files.
- Routing Sheet template - Can be in OMTPL, RTF, DOC, HTM, or HTML file format.
 - Routing Sheet display name - must be in the WTX file format and have the same name as the Routing Sheet template file.
More about routing sheets
Customizing routing sheets
Routing sheets are created from routing sheet templates on the server. These routing sheet templates can be customized to suit the needs of your company. You can modify the routing sheet templates installed on the server and create new routing sheet templates that might have general or specific uses in your company.
After you customize routing sheet templates for your company and store them in the appropriate directory on the  server,
Using a cover page routing sheet
While the routing sheet's primary function is to carry an outbound message's Embedded Directive to the server, the routing sheet also serves as a cover page for the message. When a user creates a routing sheet, the user can choose to include the routing sheet as part of the delivered message, or omit the routing sheet from the delivered message.
Note: The routing sheet must be either the first page or the last page in order to detect and create messages.
Creating Routing Sheet Templates Guidelines
Routing Sheet Template Variables List
