Supported Bar Codes and Bar Code Data Extraction
                                            The Data Extractor Component supports the detection of QR, 2D and 1D bar codes within documents. Barcoded data can be extracted and mapped from documents passing through the server.
Using Regular Expressions, the Data Extractor allows the server to detect and process barcoded cover sheets (or separator pages) generated by third-party systems.
Setting bar code data extraction
To set data extraction, you can use a control file and set:
prDataExtraction = Mode
where Mode is the sum of one or more of the following:
None = 0,
Barcode1D = 1
Barcode2D_PDF417 = 2
Barcode2D_DataMatrix = 16
Barcode2D_QR = 32
For example, to extract 1D, 2D and QR barcodes set: prDataExtraction=33
Supported bar codes
Upland AccuRoute supports the following 2D barcodes.
PDF417
QR Code
In addition, these 1D barcodes are supported.
                                                             Member  |
                                                             Value  |
                                                             Description  |
| cibf4State | 33554432 | 4State postal bar codes: USPS Intelligent Mail, British Postcode, Australian Postcode |
| cibfAddon2 | 512 | Addon-2 bar code |
| cibfAddon5 | 1024 | Addon-5 bar code |
| cibfAirline2of5 | 524288 | IATA bar code |
| cibfCodabar | 8 | Codabar bar code |
| cibfCode128 | 4 | Code 128 bar code |
| cibfCode32 | 8388608 | Code 32 bar code |
| cibfCode39 | 2 | Code 39 bar code |
| cibfCode93 | 64 | Code 93 bar code |
| cibfDatalogic2of5 | 131072 | Datalogic bar code |
| cibfEan13 | 256 | EAN-13 bar code |
| cibfEan8 | 32 | EAN-8 bar code |
| cibfIndustrial2of5 | 65536 | Industrial bar code |
| cibfInterleaved2of5 | 1 | Interleaved 2 of 5 bar code |
| cibfMatrix2of5 | 262144 | Matrix barcode |
| cibfPatch | 2097152 | Patch barcode |
| cibfPostnet | 16777216 | Postnet or Planet bar code |
| cibfUcc128 | 1048576 | UCC-128 bar code |
| cibfUpca | 16 | UPC-A bar code |
| cibfUpce | 128 | UPC-E bar code |
About Data Extractor Component
Configuring Regular Expressions and Forms Recognition
Text PDF Form Identification and Zonal Field Extraction
Creating Routing Sheet Templates Guidelines
